Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
MacBook Air 11" (Mid 2011-Early 2015) Battery
  • MacBook Air 11" (Mid 2011-Early 2015) Battery / Fix Kit
  • MacBook Air 11" (Mid 2011-Early 2015) Battery / Part Only
  • 360°
360
$84,99
$84,99
Ürün Detayı
Açıklama
Açıklama
This MacBook Air 11" (Mid 2011-Early 2015) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4850 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with Mid 2011 to Early 2015 model 11" MacBook Airs. Factory-installed MacBook Air batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit İçeriği
Kit İçeriği
Uyumluluk
Uyumluluk
  • MacBook Air 11" A1370 Mid 2011
  • MacBook Air 11" A1465 Mid 2012 to Early 2015
Teknik Özellikler
Teknik Özellikler
Model #:
A1495
Watt Hours:
38.75 Wh
Voltage:
7.6 V
Milliamp Hours:
5100 mAh
Manufacturer:
Aftermarket
Uyumluluk
MacBook Air 11" Early 2014
A1465 (EMC 2631) 1.4 GHz
A1465 (EMC 2631) 1.7 GHz
MacBook Air 11" Early 2015
A1465 (EMC 2924) 1.6 GHz
A1465 (EMC 2924) 2.2 GHz
MacBook Air 11" Mid 2011
A1370 (EMC 2471) 1.6 GHz
A1370 (EMC 2471) 1.8 GHz
MacBook Air 11" Mid 2012
A1465 (EMC 2558) 1.7 GHz
A1465 (EMC 2558) 2.0 GHz
MacBook Air 11" Mid 2013
A1465 (EMC 2631) 1.3 GHz
2 cihaz daha göster
Müşteri Yorumları
