Sorunum
My trackpad was cracked and couldn't click
Tamirim
It went well.
Önerim
I suggest using a desk lamp, bright flashlight, or any bright light. I also recommend using a small magnifying glass.
Bu ürün ülkenizde mevcut değil.
Ürün Kodu: IF108-054-3
$109,99
Satılık
A-Stok kullanılmış parçalar mükemmel durumda
B-Stok parçalarının dış yüzeylerinde ufak tefek hasarlar var
C-Stok parçalarının dış yüzeyleri ciddi şekilde hasar görmüş ancak tamamen kullanılabilir durumdalar
$109,99
Satılık
Stokta Yok
Bizde bu kadar stok mevcut değil
Ürün Detayı
Açıklama
Açıklama
Replace a damaged trackpad and restore the touch sensitivity of your Mid 2013 to Early 2015 model 11" MacBook Air laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control. Fix these issues with this replacement part.
Uyumluluk
Uyumluluk
Teknik Özellikler
Teknik Özellikler
Uyumluluk
Onarım hikayeleri
It went well.
When attempting to clean and adjustment the trackpad I ended up breaking the keyboard ribbon cable zif connector - So I ended up having to purchase a new trackpad.
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyboard ribbon. My laptop now works great - so I'm happy.
Be really careful when lifting the zif connectors to remove and insert the ribbons. It's very thin plastic and if it breaks you have to replace the entire trackpad. I used the All-new Pro Tech Toolkit, which is awesome. Great tools, great case. Highly recommend this kit - I
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyb . . .
Müşteriler Bunları da Satın Aldı
