Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Mac MacBook Air MacBook Air 13" MacBook Air 13" Early 2020 Case Components
Mağaza
Grab a toolkit for your MacBook Air 13" Early 2020 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
MacBook Air 13" (Late 2018-Early 2020) Trackpad / New / Dark Gray
Replace a trackpad compatible with a Late 2018 to Early 2020 MacBook Air 13" laptop models A1932 and A2179.
$49,99'den
MacBook Air 13" (Late 2018-Early 2020) Audio Daughterboard Cable Bracket
Replace a bent or missing metal bracket securing the audio daughterboard cable connector to the display daughter board in a late 2018 to early 2020 model 13" MacBook Air.
$0,99'den
MacBook Air 13" (Late 2018-Early 2020) Lower Case / New / Dark Gray
Replace a scratched or dented lower case for a Late 2018 to Early 2020 13" MacBook Air.
$55,99'den
MacBook Air 13" (Late 2018-Early 2020) Display Cable Bracket
Replace a bent or missing metal bracket securing the display cable connector to the display daughter board in a late 2018 to early 2020 model 13" MacBook Air.
$0,99'den
MacBook Air 13" (Late 2018-Early 2020) USB-C Cable Bracket
Replace a bent or missing bracket that secures the USB-C cable to the logic board in a 2018 to early 2020 model 13" MacBook Air.
$2,99'den
MacBook Air 13" (Early 2020) Upper Case with Keyboard / A-Stock / Dark Gray
Replace an upper case and keyboard compatible with the Early 2020 model A2179 MacBook Air 13 inch laptop. Includes the keyboard and palm rest area.
$199,99'den
MacBook Air 13" (Early 2020) Antenna Bar Cable Bracket / Used
Replace a bent or missing bracket that secures the antenna bar cable compatible with the Early 2020 Model A2179 13 inch MacBook Air laptop.
$7,99
MacBook Air 13" (Early 2020) Trackpad Cable Bracket / Used
Replace a bracket that secures the trackpad cable to the logic board compatible with the early 2020 model 13" MacBook Air laptop.
$5,99
8 Üründen 1 - 8 arası ürün gösteriliyor
Cihaz Bilgisi
This minor refresh of the Retina MacBook Air has a new model number, A2179, and has the EMC number 3302. This model features a new keyboard with a scissor mechanism, updated processor, and some slightly-revised internals that allow for easier trackpad and battery replacements.
Introduced in March 2020 this model is equipped with two Thunderbolt 3 ports and one headphone jack. Internally it features a 13.3 inch display with native 2560 x 1600 pixel resolution.
