Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parts Mac MacBook Air MacBook Air 13" Logic Boards
Mağaza
Grab a toolkit for your MacBook Air 13" model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
MacBook Air 13" (Mid 2013-Early 2014) 1.7 GHz Logic Board
Replace a 1.7 GHz logic board (motherboard) in your Mid 2013 to Early 2014 MacBook Air 13" model laptop. Includes 4 or 8 GB RAM. Fix processing issues like unexpected shu...
$349,99'den
MacBook Air 13" (Mid 2013-Early 2014) 1.4 GHz Logic Board
Replace a 1.4 GHz logic board (motherboard) compatible with the early 2014 MacBook Air 13" model laptop. Fix processing issues like unexpected shutdowns, reboots or water...
$249,99'den
MacBook Air 13" (Mid 2011) 1.7 GHz Logic Board
Replace a 1.7 GHz logic board (motherboard) compatible with the Mid 2011 MacBook Air 13" model laptop. Fix processing issues like unexpected shutdowns, reboots or water d...
$249,99
MacBook Air 13" (Early 2020) 1.1 GHz Core i3 Logic Board with Paired Touch ID Sensor / 8 GB RAM / 256 GB SSD
Replace a logic board (motherboard) compatible with the Early 2020 model 13" MacBook Air. 1.1 GHz. Includes an Integrated Intel Iris Plus GPU, RAM, SSD, and Paired Touch ...
$599,99'den
MacBook Air 1.8 GHz (Original) Logic Board
Replace a logic board (motherboard) compatible with the MacBook Air 1.8 GHz (Original) laptop. Includes 2 GB RAM. Fix processing issues like unexpected shutdowns, reboots...
$299,99
MacBook Air 13" (Mid 2011) 1.8 GHz Logic Board
Replace a 1.8 GHz logic board (motherboard) compatible with the mid 2011 MacBook Air 13" model laptop. Includes 4 GB of RAM. Fix processing issues like unexpected shutdow...
$308,99
MacBook Air Logic Board Bracket
Replace a logic board bracket compatible with the MacBook Air model laptop. This bracket clamps the Airport/Bluetooth cable and trackpad control cable to the logic board.
$4,99
MacBook Air 13" (Mid 2012) 1.8 GHz Logic Board
Replace a 1.8 GHz logic board compatible with the Mid 2012 MacBook Air 13" model laptop. Includes 4 or 8 GB RAM. Fix processing issues like unexpected shutdowns, reboots ...
$199,99'den
MacBook Air (Original) Processor Clamp
This bracket clamps the heat sink onto the main processor.
$7,99
MacBook Air 13" (Mid 2012) 2.0 GHz Logic Board / 8  GB
Replace a 2.0 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Air 13" model laptop. Fix processing issues like unexpected shutdowns, reboots or water d...
$224,99'den
23 Üründen 1 - 10 arası ürün gösteriliyor
Cihaz Bilgisi
When the MacBook Air was released, it was the thinnest notebook computer yet. A minimalist port design and multitouch trackpad are characteristic of the MacBook Air.
In October of 2010, Apple introduced a total redesign of the MacBook Air 13". The new Air features a flash memory module instead of a conventional hard drive, and the battery dominates most of the internal space. This lack of conventional hard drive allows the machine to be insanely thin.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your machine above for parts and more!
