MacBook Air (Original) Fan and Heat Sink
  • MacBook Air (Original) Fan and Heat Sink
$39,99
$39,99
Ürün Detayı
Açıklama
Açıklama
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1237 MacBook Air to overheat and eventually damaging your processors. Replace a defective fan and heat sink to fix overheating problems or to keep your laptop running quietly.
Parça Montajında olanlar:
  • Fan
  • Attached Heat Sink
Uyumluluk
Uyumluluk
  • 1.6 or 1.8 GHz Original MacBook Airs
Teknik Özellikler
Teknik Özellikler
Part #:
922-8316
Kurulum Videosu
Uyumluluk
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
The fan was making a whistle noise... and the CPU was too hot for MBA to work normally.
Tamirim
Changed the fan. Cleaned the inside of the laptop from dust…
Önerim
Clean the inside at least twice a year…
Kullanıcı avatarı
Sorunum
Existing fan was loud
Tamirim
The repair went according to instructions. I like how all the different screws are identified. Made it really easy for reinstallation.
Önerim
Ifixit shows instructions on how to remove the fan from the heatsink but does not offer the option of buy the fan only. I had to buy the heatsink . . .
Kullanıcı avatarı
Sorunum
The machine began to run a little hot with excessive fan activity. Eventually no fan, just a faint clicking sound and rising temperatures, which I diagnosed from various blogs as fan failure.
I hadn't checked the heatsink vs processor temperatures so couldn't confirm the state of the heat sink / . . .
Kullanıcı avatarı
Sorunum
So, my original MacBook Air's fan started making a *horrible* very, un-Apple-like screeching sound. I added some lubrication and that helped a little, but in the end it appeared the fan unit itself had just worn out after working at thousands of RPMs for many hours thru the years.
Tamirim
The repair took abo . . .
Daha fazla göster
