MacBook Air 13" Original Case Components
Grab a toolkit for your MacBook Air 13" Original model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Air 13" Original ile çalışan parçalar:
MacBook Air (Original) Upper Case with Keyboard
Replace an upper case compatible with the Original MacBook Air laptop. Includes the keyboard, palmrest area, power button, and trackpad. Part #922-8315.
MacBook Air (Original) Lower Case
Replace a scratched or dented lower case.
MacBook Air Airport/Bluetooth Bracket
Replace the plastic bracket that houses the Airport and Bluetooth Board compatible with the A1237 Original or A1304 Late 2008 to Mid 2009 MacBook Air 13 inch laptop. Part...
Cihaz Bilgisi
The MacBook Air only has a few user upgrade possibilities. You can, however, swap out a bad battery with a replacement battery using our battery repair guide. With our hard drive replacement guide, you can increase your storage space by replacing your 80 GB 1.8" hard drive with a larger 120 GB 1.8" hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
We offer parts for every need to resurrect your machine, from case components and cables to displays and logic boards. Select your category below or browse all compatible parts to find what you need to fix your laptop!
