Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
MacBook Front Display Bezel
  • MacBook Front Display Bezel / White
  • MacBook Front Display Bezel / Black
$4,99
$4,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Nintendo Switch Kit'leri
Oyuna geri dönmek için hızlı bir düzeltme
Switch Kit'leri Satın Al
Ürün Detayı
Açıklama
Açıklama
Replace a scratched or cracked MacBook front display bezel with camera hole.
Uyumluluk
Uyumluluk
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Teknik Özellikler
Teknik Özellikler
Part #:
922-7776, 922-7598, 922-8009
Uyumluluk
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2139) 2.16 GHz
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
Onarım hikayeleri
Kullanıcı avatarı
Zachary Wheeling's Story Photo #750163
Sorunum
MacBook Core 2 Duo 2.16 Ghz 4GB RAM 240GB Intel SSD 160GB Apple HDD..... Screen Bezel clips were broken and wanted to change color from black to white. Also wanted a dual hard drive as I had recently purchased an SSD to speed up my MacBook C2D and wanted to run three Mac OS's as well as a copy of . . .
Kullanıcı avatarı
Sorunum
classic cracking in the display bezel and topcase palmrest. Felt like the Mac desirved to be refurbished after the fond college memories
Tamirim
followed the online takeapart guide, was easy as 1 2 3
Önerim
make sure to retain the plastic fitting clips when removing the old front bezel frame, they are needed in ord . . .
Kullanıcı avatarı
Sorunum
Spilled iced tea all over my upper case and my front bezel was showing some age
Tamirim
It went well thanks to the guides
Önerim
Diy
Kullanıcı avatarı
Sorunum
Bezel was cracked in assorted places.
The right and left arrow keys quit working.
The trackpad and select (long key below the trackpad) had issues.
Tamirim
I followed the guides and used the plastic bag method to keep track of the screws, at each step I numbered the bag to the step in the instructions. I fou . . .
Kullanıcı avatarı
Sorunum
Right and Left arrow keys stopped working
The actuator key below the track pad was sticking.
The bezel was cosmetic .
Mac Store wanted almost $400.00 to do the Fix
Tamirim
When I removed the screws with Fixit instructions The some of the screws were in the wrong holes. this unit had been fixed at a
"mac "re . . .
Kullanıcı avatarı
Sorunum
The screen in the MacBook (Early 2009) had no light. First I changed the inverter and inverter cable but still no light. So I decided to change the LCD panel as well and this did the trick.
Tamirim
I followed the guide to change the LCD panel and had no big problems.
Önerim
Invest in proper tools! Screwdrivers and . . .
Kullanıcı avatarı
Sorunum
It had begun to crack in a few spots.
Tamirim
The repair went very well. I did not need to remove the screen to install the bezel.
Önerim
Be extra careful with the small clips that help hold the bezel. They are delicate. Pry gently and try to avoid damaging the clips. Use a small flat blade to help install the clip . . .
Kullanıcı avatarı
Sorunum
MacBook mid-2007 13" screen cracked when lid pushed too far back. Front display bezel showed signs of wear so decided to replace it at same time.
Tamirim
Parts came on time and safely packed. Printed out guide and followed it religiously. Bought very good small screwdriver set at Home Depot for about $1 . . .
Kullanıcı avatarı
Sorunum
Because it was broken in half
Tamirim
Very well
Önerim
Always buy from iFixIt.com
Daha fazla göster
