MacBook/MacBook Pro 15" 8x SuperDrive
  • MacBook/MacBook Pro 15" 8x SuperDrive / OEM
Non Apple logo drive.
Koşul: Kullanılmış
$69,99
$69,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Ürün Detayı
Açıklama
Açıklama
Replace a broken or damaged 8x SuperDrive for MacBook or MacBook Pro 15" with this part.
Uyumluluk
MacBook Core 2 Duo
1.83 GHz
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
MacBook Pro 15" Core 2 Duo Model A1211
2.16 GHz
2.33 GHz
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz
2 GHz
2.16 GHz
2 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
meredith's Story Photo #387087
meredith's Story Photo #387090
Sorunum
I wanted to install Ubuntu on my 2006 MacBook (2,1) and run it side by side with Mac OS X, but my optical drive failed, so I could not get Ubuntu loaded.
Tamirim
I ordered a new optical drive from ifixit.com as well as new battery (which has died long ago, but I never did anything about it). I also ordered . . .
Kullanıcı avatarı
Sorunum
noisy fans and not yet working cd rom
Tamirim
all good
Önerim
no
Kullanıcı avatarı
Sorunum
I had a CD stuck in my CD/DVD drive so I called Apple support and they talked me through all the remedies, none of which worked. So then I made a Genius Bar appointment and they got the CD out but then I had an awful, continuous noise (the sound of the drive trying to eject) and the drive no longer . . .
Kullanıcı avatarı
Sorunum
The DVD player in my wife's early 2008 MacBook Pro stopped playing DVD's reliably. We RV full-time, and her computer is her TV. She watches 4 to 6 DVD's a week, and a new computer wasn't an option. (A new Mac wouldn't have a DVD drive anyway!)
Tamirim
Repair was pretty easy. I've worked on this model before, . . .
Kullanıcı avatarı
Sorunum
The SuperDrive would not accept a disk.
Tamirim
The repair went very smoothly.
Önerim
Step 10 of the repair guide suggests you remove the ribbon cable attaching the SuperDrive connector to the logic board. I found this to be unnecessary. After removing the three screws holding the drive in place, I was able to lift . . .
Kullanıcı avatarı
Sorunum
fan and drive died
Tamirim
having built computers, made repairs, this was simple.
Önerim
iFixit provides you with pictures that are worthless without an internet connection and an extra computer to view while you fix yours. Nothing ventured is nothing gained. Look at pictures; figure it out; go for it.
Kullanıcı avatarı
Sorunum
The superdrive on my MBP gave up the ghost a while ago and I went without it for a while. Eventually I decided I needed to do something about it and on a whim searched for replacement drives. I found iFixit and after a little reading decided to go for it.
Tamirim
Easy to replace - but also very easy to lo . . .
Kullanıcı avatarı
Sorunum
I have a MacBook Pro that I have had for about 4 years, which for me is a record. It just won't die. And the pieces that do die, places likeifixit make it so easy to replace. My SuperDrive decided it would no longer read DVD's or DVD-DL's. Ordered one, and 10 minutes later the problem was solved! A . . .
Kullanıcı avatarı
Sorunum
The stock drive on my MBP had been slowly declining for some years. Finally died, so had to replace it.
Tamirim
Repair was pretty easy with the help of the on-line instructions. Drive now works like a charm.
Önerim
No
Kullanıcı avatarı
Sorunum
MacBook Core 2 Duo, 2Ghz, Black model, Late 2006, A1181.
Bluetooth not found, Heat on cpu-core up to 90 degrees Celsius, Fan got noisy and Dvd not accepting or ejecting disks.
I don't know ware the magic has gone. It's not here any more.
Tamirim
After a "practice run" before I got my parts everything . . .
Daha fazla göster
