Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Two Thunderbolt Ports Late 2020 Case Components
Mağaza
Grab a toolkit for your MacBook Pro 13" Two Thunderbolt Ports Late 2020 model A2338 and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
MacBook Pro 13" (A2338, Late 2020) Trackpad / New/ Dark Gray
Replace a scratched or malfunctioning trackpad compatible with a Late 2020 model A2338 MacBook Pro 13" with Two Thunderbolt Ports.
$79,99'den
MacBook Pro 13" (A2289, A2338, 2020) Upper Case Assembly / A-Stock / Silver
Replace an upper case, keyboard, and battery compatible with a 2020 model A2289 or A2338 MacBook Pro 13 inch laptop with two Thunderbolt Ports.
$399,99
MacBook Pro 13" Retina (Late 2016-2020) Display Cable Brackets
Replace the brackets that secure the display cable connector to the display daughter board and clamp the middle of the cable to the upper case assembly in a 2016 to 2020 ...
$4,99
MacBook Pro 13" (A2338, Late 2020) Lower Case / New / Dark Gray
Replace a scratched or dented lower case compatible with a late 2020 model A2338 13" MacBook Pro with two thunderbolt ports.
$99,99
MacBook Pro 13" (A2338, Late 2020) 3.2 GHz Logic Board with Paired Touch ID Sensor / 8 GB / 256 GB
Replace a damaged or malfunctioning 3.2 GHz M1 Motherboard. The Touch ID sensor is paired to the logic board and is included.
$599,99'den
MacBook Pro 13" (2020) Touch Bar and USB-C Cable Bracket
Replace a bent or missing bracket that secures the touch bar cable and one USB-C cable to the logic board in a 2020 model A2251, A2338, or A2289 13" MacBook Pro laptop.
$79,99
MacBook Pro 13" (A2289, A2338, 2020) Headphone Jack and Microphone Cable Bracket
Replace a bent or missing bracket that secures the headphone jack and microphone cables in a 2020 model A2289 or A2338 13" MacBook Pro with two Thunderbolt ports.
$9,99
MacBook Pro 13" (A2159, A2289, A2338) Headphone Jack Cable Bracket
Replace a bent or missing bracket that secures the headphone jack cable in a 2019 or 2020 model A2159, A2289, or A2338 13" MacBook Pro with two Thunderbolt ports.
$9,99
MacBook Pro 13" (A2338, Late 2020) Trackpad Cable Bracket
Replace a bent or missing metal bracket that secures the trackpad cable connector to the logic board compatible with a late 2020 model A2338 13 inch MacBook Pro with Two ...
$24,99
MacBook Air 13" and MacBook Pro 13" (A2337, A2338, Late 2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a late 2020 model A2337 or A2338 13" MacBook Air or MacBook Pro laptop.
$9,99
10 Üründen 1 - 10 arası ürün gösteriliyor
Cihaz Bilgisi
Released in Late 2020, this 13" Macbook Pro features Apple's M1 3.2 GHz 8-core CPU, 16-core Neural Engine processors. Model A2338.
The most common repairs with the 13" Late 2020 model MacBook Pro 13" with Two Thunderbolt Ports laptops are replacing a dead battery or a damaged display assembly.
The battery is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Late 2020 repair guides for step-by-step instructions on how to make the fix.
