MacBook Pro 13" Heat Sinks
Grab a toolkit for your MacBook Pro 13" model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 13" modelinizi seçin:
MacBook Pro 13" ile çalışan parçalar:
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Heat Sink
Replace a damaged heat sink compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar. The heat sink dissipates heat from the CPU.
MacBook Pro 13" Unibody (Early 2011-Late 2011) Heat Sink
This part attaches to the processor and helps dissipate heat.
MacBook Pro 13" Unibody (Mid 2012) Heat Sink
Replace a bent or damaged heat sink compatible with a mid 2012 model 13" MacBook Pro Unibody laptop.
MacBook Pro 13" Retina (Late 2012-Early 2013) Heat Sink
MacBook Pro 13" Retina Fan Ducts
Replace the elastic gaskets that direct the airflow from the fans to the heat sink compatible with the A1425 model Retina 13 inch MacBook Pro laptop. Part #923-0228.
MacBook Pro 13" Retina (Late 2013-Early 2015) Heat Sink
Replace a damaged heat sink. This part dissipates heat generated by your computer's processors.
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Heat Sink
Replace a damaged heat sink in a 2016 or 2017 model 13" MacBook Pro with Retina Display and function keys.
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 13" Unibody (Mid 2010) Heat Sink
Cihaz Bilgisi
Catering to the working professional, the MacBook Pro 13" is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
Select your version above for parts and assistance!
