Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
  • MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
$499,99
$499,99
Ürün Detayı
Açıklama
Açıklama
This Late 2012 to Early 2013 MacBook Pro 13" Retina replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
Parça Montajında olanlar:
  • 2560 x 1600 13.3" Retina LCD Screen
  • Display Cover
  • Bezel
  • FaceTime HD Camera
  • Clutch Hinges
  • Wi-Fi Antenna
  • Camera
  • Display Data Cables
Uyumluluk
Uyumluluk
  • MacBook Pro 13" Retina A1425 Late 2012 to Early 2013
Teknik Özellikler
Teknik Özellikler
Part #:
661-7014
Size:
13.3"
Resolution:
2560x1600
Uyumluluk
MacBook Pro 13" Retina Display Early 2013
A1425 (EMC 2672) 2.6 GHz
A1425 (EMC 2672) 3.0 GHz
MacBook Pro 13" Retina Display Late 2012
A1425 (EMC 2557) 2.5 GHz
A1425 (EMC 2557) 2.9 GHz
Onarım hikayeleri
Kullanıcı avatarı
jimpandolfo's Story Photo #901875
jimpandolfo's Story Photo #901873
jimpandolfo's Story Photo #901878
Sorunum
Coating was coming off my retina screen.
Tamirim
The web site instructions were spot on! The repair was easy and fun to do. I had 0 issues. Thanks!!!
Önerim
As long as you follow the directions, it's an easy repair. Took me less than 30 minutes
Kullanıcı avatarı
Phil Wymore's Story Photo #858008
Sorunum
Cracked Retina display
Tamirim
It couldn't have been easier -- in fact it was actually fun. The tools were perfectly matched for each task and the instructions were very easy to follow.
Önerim
Don't be intimidated
Kullanıcı avatarı
Sorunum
Crack in display
Tamirim
Very good, the only difficult part was to replace the new display and connect it with the first 2 screws.
Önerim
Kullanıcı avatarı
Sorunum
I carelessly put a small crack in my previous screen and after getting an estimate from a shifty guy at the Apple store I would have been better off replacing the whole Macbook. I'm in college and I need to save the money.
Tamirim
The process was smooth and easy with excellent steps and pictures to help buls . . .
Kullanıcı avatarı
Sorunum
Cracked display.
Tamirim
Smoothly.
Önerim
Must have proper screwdrivers (Torx 2, 5, 6, 7, and 8, I believe).
Kullanıcı avatarı
Sorunum
My old retina display was dying. I had a streak of dying pixels down the left side of my monitor
Tamirim
The replacement was simple thanks to IFIXIT! Before even cracking open the case I knew which tools I needed, the task at hand, and the basic time I would need to allot for the job. I swapped out my lid as . . .
Kullanıcı avatarı
Sorunum
The screen was damaged when the laptop was dropped
Tamirim
Screen replaced
Önerim
I had someone experienced in repairing my laptop complete the repair. Very satisfied and happy with the outcome.
Daha fazla göster
