MacBook Pro 13" Unibody (Mid 2009) 2.26 GHz Logic Board
  • MacBook Pro 13" Unibody (Mid 2009) 2.26 GHz Logic Board
  • 360°
360
$99,99
$99,99
Ürün Detayı
Açıklama
Açıklama
Replace the 2.26 GHz logic board in your MacBook Pro 13" Unibody (Mid 2009) and fix processing issues.
  • Included Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Uyumluluk
Uyumluluk
  • MacBook Pro 13" Unibody A1278 Mid 2009
Teknik Özellikler
Teknik Özellikler
Part #:
661-5230
Speed:
2.26 GHz
GPU:
NVIDIA GeForce 9400M
Uyumluluk
MacBook Pro 13" Unibody Mid 2009
A1278 (EMC 2326) 2.26 GHz
A1278 (EMC 2326) 2.53 GHz
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
When to start system operative is it very slow, although it had already been replaced the HDD for SSD, and the flex is okay.
Tamirim
the original heatsink did not hunt with this board that I received
Önerim
you should always to use anti-static bracelet
