MacBook Pro 13" Unibody and MacBook 13" Unibody Fan
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / New / Black
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Silver
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Black
$39,99
$39,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Ürün Detayı
Açıklama
Açıklama
Replace a broken, damaged, or otherwise underperforming fan for your MacBook Pro 13" Unibody (Mid 2010-Mid 2012) or MacBook 13" Unibody (all models) with this part.
Parça Montajında olanlar:
  • Fan
  • Surrounding metal bracket
Kurulum Videosu
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
The fan sounded like it was dying.
As I was leaving one day, it started running, and I was sure that someone was outside using a weedeater. Then I remembered it was winter and snow was everywhere, so that probably wasn't the case.
Tamirim
Pretty painlessly. I read some reviews hearing that it didn't go as w . . .
Kullanıcı avatarı
Sorunum
I suppose my computer is ancient considering many machines are replaced at 2ish years. Anyway, fan was making terrible clicking/rattling sounds after a suffering a light drop from a low bed onto carpet.
Tamirim
Easy peasy, lemon squeezy.
Önerim
None. If you know how to use a screw driver, you can make this repair.
Kullanıcı avatarı
Sorunum
The fan had been making a loud grinding noise. It also couldn't reach it's max RPM.
Tamirim
It was very straightforward.
Önerim
Be slow and patient; the connectors are very delicate. Also, keep track of the screws!
Kullanıcı avatarı
Sorunum
Wife's Macbook Pro 13" fan stopped working
Tamirim
Literally took off the Phillips screws holding bottom cover, took 3 Torx 6 screws out, unplugged fan from board, took out fan, put new one in, plugged into board, put Torx 6 screws back in, and put Phillips back in. Worked like a charm.
Önerim
Screws had tiny bump o . . .
Kullanıcı avatarı
Sorunum
The fan was getting noisy but still working. I knew its days were numbered
Tamirim
super easy. While i was in there I decided to upgrade the HD to an SSD also. With the tutorials on Ifixit it was all super easy.
Önerim
Don't be afraid to try repairs on your MacBook Pro. It's much easier than you think with the tutor . . .
Kullanıcı avatarı
Sorunum
My MBP has been making this grinding noise that I originally thought was the HDD failing (again). Turned out it was the fan going bad. When I ran a YouTube video my CPU temperature spiked to high 80's and you could hear the fan screaming for mercy. lol :)
Tamirim
The most difficult part of the repair was wa . . .
Kullanıcı avatarı
Sorunum
The fan had completely quit in my 2012 unibody macbook pro and as a result it was overheating and slowing the cpu to a crawl during taxing graphical work.
Tamirim
The new fan fit perfectly and works perfectly and silently. I'm far more confident in its brushless motor to hold up.
Önerim
The fans don't come with hard . . .
Kullanıcı avatarı
Sorunum
My fan was making my MacBook sound louder than a blender!
Tamirim
Super easy and straight forward.
Önerim
Don't be afraid to make your own repairs. I recently also double the memory sticks on my MacBook and it is now nice and quiet and lightning fast. Having said the, do know your limitations.
Kullanıcı avatarı
Sorunum
The fan was noisy, and it sounded like it was on the way out
Tamirim
All good until it came to levering the fan connector out with the spudger. Then -- as predicted in the instructions -- disaster! All four pins from the logic board sheared off, firmly in the fan connector. Fortunately my local computer tech . . .
Kullanıcı avatarı
Sorunum
The fan was beginning to make a screeching racket and the mac case was getting hotter than it ever had before, then it went quiet and made no noise! So after conferring with a friendMacGuru I presumed that at least the fan could do with replacement immediately lest I need to replace the lot imminent . . .
Daha fazla göster
