MacBook Pro 15" Unibody (Late 2008 or Early 2009) Logic Boards
Grab a toolkit for your MacBook Pro 15" Unibody (Late 2008 or Early 2009) model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
MacBook Pro 15" Unibody (Late 2008 or Early 2009) modelinizi seçin:
MacBook Pro 15" Unibody (Late 2008 or Early 2009) ile çalışan parçalar:
MacBook Pro 15" Unibody (Late 2008-Early 2009) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Late 2008 to Early 2009 MacBook Pro 15" Unibody laptop. Fix processing issues like unexpected shutdowns, r...
MacBook Pro 15" Unibody (Late 2008) 2.53 GHz Logic Board
Replace a 2.53 GHz logic board (motherboard) compatible with the Late 2008 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire ...
MacBook Pro 15" Unibody (Early 2009) 2.66 GHz Logic Board
Replace a 2.66 GHz logic board (motherboard) compatible with the early 2009 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire...
MacBook Pro 15" Unibody (Early 2009) 2.93 GHz Logic Board
Replace a 2.93 GHz logic board (motherboard) compatible with the Early 2009 MacBook Pro 15" Unibody laptop. Included Ports: Mini DisplayPort, 1000BaseT Ethernet, Firewire...
Cihaz Bilgisi
In October of 2008 Apple released the MacBook Pro 15" Unibody with a new aluminum case drilled from a single aluminum brick. This model introduced some features that were new to Apple laptops: dual video cards, one for power saving casual use and one for graphics-intensive processing, and a Mini DisplayPort replaced the full-size DVI display connector.
The most common repairs with Late 2008 and Early 2009 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Late 2008-Early 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Late 2008 & Early 2009 repair guides for step-by-step instructions on how to make the fix.
