MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Right Fan
  • MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Right Fan
$39,99
$39,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Ürün Detayı
Açıklama
Açıklama
Replace the right fan for your Late 2008 through Mid 2012 Unibody 15" MacBook Pro (excluding Mid 2009 2.53 GHz) with this part. This part includes the fan and its surrounding metal bracket.
Uyumluluk
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
3 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
Baron's Story Photo #898994
Sorunum
In photo old fan on left, replacement (used fan) on right. The old fan was slowing down 0-200 rpm when it should have been going 3K rpm. It was making a lot of noise like maybe the bearings were shot.
Tamirim
I purchased a used Right Fan from iFixit for my Mid-2010 MacBook Pro since it still cam with a lifet . . .
Kullanıcı avatarı
Sorunum
to much noise to produce music and video.
Tamirim
it went very well.
Önerim
Just use the correct tools to repair your devices and do it yourself, it's funny
Kullanıcı avatarı
Sorunum
Had to change the battery in my 5 year old MacBook Pro 15"
Tamirim
The service and delivery speed was top notch!
Installed the new battery I got from Ifixit.
What bothers me is that the new battery is not as good as I expected.
It drains fairly quickly, almost the same speed as the old one.
The situation i . . .
Kullanıcı avatarı
Sorunum
The fan is so loud. Sound like the fan is ripping itself apart and my MacBook Pro got very warm
Tamirim
Following the instruction. It was quite easy and fast.
Önerim
Get all the tool first
Kullanıcı avatarı
Sorunum
The fans on my MacbookPro had been running constantly due to some software that seemed to need 1 CPU to run constantly to check web pages. After finally figuring out which software to trash and reducing use of the fan, the wear and tear of this bad software took its toll and eventually the fans sta . . .
Kullanıcı avatarı
Sorunum
My old fan was rattling and I had to hit my Macbook in order to stop it.
Tamirim
The fan is probably one of the easiest things to replace.
Önerim
I wish I had gone to ifixit before. Real quick and easy repair. Will buy from again.
Kullanıcı avatarı
Sorunum
My brother's Macbook Pro was making some interesting sounds on top of overheating. We did some research and came across ifixit.com how-to articles. From there, I ordered the fans (used), and the problem was fixed!
Tamirim
Removing and replacing the right and left fans (Macbook Pro 15 mid-2009 2.8 GHz model) . . .
Kullanıcı avatarı
Sorunum
fans started making grinding noise so had to replace
Tamirim
No problems. Easy and didn't take long
Önerim
Make sure to clean out the intake grills before you switch up your fans, and it's probably a good idea to start cleaning out that dust every 6 months or so
Kullanıcı avatarı
Sorunum
Mis ventiladores hacían muchísimo ruido, ni se iba con lubricante especial para ventiladores.
Tamirim
Ventiladores como nuevo. Silencio absoluto. Paquete bien protegido. Atención, servicio y rapidez de entrega inmejorable.
Valoración 12 sobre 10.
Önerim
Lamento que en su página en Europa, no tengan existencias, . . .
Kullanıcı avatarı
Sorunum
leftFAN noises and damaged
rightFAN was ok but i want to change it
Tamirim
All perfect, except for the rightFAN. I can't unscrew the old one, the screw is locked!
Önerim
nn
Daha fazla göster
