Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board
  • MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board
$358,99
$358,99
Ürün Detayı
Açıklama
Açıklama
Replace the 2.0 GHz Core i7 logic board in your MacBook Pro 15" Unibody (Early 2011) and fix processing issues.
  • Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Uyumluluk
Uyumluluk
  • MacBook Pro 15" Unibody A1286 Early 2011 to Late 2011
Teknik Özellikler
Teknik Özellikler
Part #:
661-5850, 661-6080
Speed:
2.0 GHz
GPU:
Dual graphics with automatic graphics switching:
Intel HD Graphics 3000 (384 MB shared)
AMD Radeon HD 6490M (256 MB dedicated)
Uyumluluk
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
Onarım hikayeleri
Kullanıcı avatarı
urjoking's Story Photo #1417305
Sorunum
I wanted to revive my old MacBook Pro, so I replaced the battery and put in an SSD. And hey presto! After getting it all set up, it failed. After a bit of research, I determined the problem was the logic board, and I thought, "I’ve come this far..."
Tamirim
I am a novice. My only experience fixing stuff ha . . .
Kullanıcı avatarı
Sorunum
Hi guys, my beautiful macbook pro (early 2011) went blank one day. I would say part of my fault, because went I heard the fans going nuts, I should have acted right away. I did wait too long as result the GPU failed, so I had no other way than swapping the logic board.
Tamirim
Well, I am extremely happy. I g . . .
