Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
MacBook Pro 15" Unibody (Late 2008-Late 2011) LCD Panel
  • MacBook Pro 15" Unibody (Late 2008-Late 2011) LCD Panel
$84,99
$84,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Essential Electronics Toolkit
Small Toolkit. Big Possibilities.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
Ürün Detayı
Açıklama
Açıklama
Replacement display panel for 15.4" Unibody displays. Compatible with all 15" Unibody MacBook Pros. 15.4” screen.
Uyumluluk
Uyumluluk
  • MacBook Pro 15" Unibody A1286 Late 2008 to Late 2011
Teknik Özellikler
Teknik Özellikler
Part #:
LP154WP3-TLA3, LP154WP4-TLA1
Size:
15.4"
Resolution:
Standard: 1440x900
High: 1680x1050
Uyumluluk
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
A1286 (EMC 2324) 2.53 GHz
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2008 & Early 2009
2.66 GHz
2.93 GHz
A1286 (EMC 2255) 2.4 GHz
A1286 (EMC 2255) 2.53 GHz
A1286 (EMC 2255) 2.8 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2009
A1286 (EMC 2325) 2.66 GHz
A1286 (EMC 2325) 2.8 GHz
A1286 (EMC 2325) 3.06 GHz
MacBook Pro 15" Unibody Mid 2010
A1286 (EMC 2353) 2.4 GHz
A1286 (EMC 2353) 2.53 GHz
A1286 (EMC 2353) 2.66 GHz
A1286 (EMC 2353) 2.8 GHz
3 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
patrash's Story Photo #229687
patrash's Story Photo #229688
Sorunum
LCD on MacBookPro was damaged and didn´t work properly
Tamirim
Like a charm!
It was a bit hard no exactly know how much heating had to be done to ensure that display glam could be removed from adhesive edge around the display. I think I accidently heated it too much and a huall area of the glam became a bi . . .
Kullanıcı avatarı
Sorunum
My lcd was bad
Tamirim
As many others have said, getting the glass off was real tough, I found that when I wasn't having success in one corner, I tried a lower corner and it worked much better. From there I just pried all the way around, making sure to heat a bit as I went.
Önerim
I bought my led from Ifixit and the . . .
Kullanıcı avatarı
Sorunum
I always try to fix things myself, and my wifes laptop screen was not going to be an exception.
Tamirim
Easy! Simple! Step by step instructions that even a monkey can learn to follow. This was my first time ever working on electronics, so it was a bit intimidating at first, but very easy. The parts i ordered . . .
Kullanıcı avatarı
Sorunum
Back of aluminum had something fall on it and dented right into the lcd , and broke it.
Tamirim
Very well , easy followed instructions did it in just under an hour for disassembling . Part arrived the next day put it in and reassembled in less time .
I had to drill out some stripped screws .. No big deal . . . .
Kullanıcı avatarı
Sorunum
Il mio schermo LCD é morto ,fuori garanzia ovviamente costo riparazione 600 euro e più. Dopo aver messo del disossidante per contatti sul connettore dello schermo ha ricominciato a funzionare , peccato che abbia rovinato lo schermo
Tamirim
Riparazione avvenuta con successo, a parte gli insetti dentro lo sc . . .
Kullanıcı avatarı
Sorunum
Screen was smashed so I had to fix it
Tamirim
This was not easy, but definitely worth the work. The instructions on this website are superb
Önerim
Make sure to keep track of which screws go where!
Kullanıcı avatarı
Sorunum
Lcd was broken, its cheaper do it by yourself
Tamirim
LCD was replaced flawlessly... the front glass didnt had the same fate.
Önerim
remove the front glass is very tricky, better consider have a spare front glass handy
Kullanıcı avatarı
Sorunum
Broken LCD w/ verticle bands of solid white/black.
Tamirim
Reasonably well. Used a hair dryer instead of a heat gun. Had a lot of trouble getting LVDS cable (also replaced) to stay in the lcd when putting everything back together.
Önerim
My LCD panel has about 50 stuck red pixels all in a clump in the lower left cor . . .
Kullanıcı avatarı
Sorunum
My mac took a bit of a tumble and the bottom quarter of the screen was distorted to just lines. Took it into to an Apple store to make sure it was the right problem and see if it would at least be around the same price as fixing it myself, but ~$500 was a little pricey for me.
Tamirim
I only had two issues c . . .
Kullanıcı avatarı
Sorunum
The late-2008 Macbook Pro 15" - after a lightning discharged quite nearby the screen acquired a bad habit of turning white washed out. Could be a coincidence or just a factor promoting a defect.
The washout could be remedied by a little pinching of the screen - so it was just a matter of time the g . . .
Daha fazla göster
