17" Unibody Early 2009 Optical Drives
Replacement parts for your 17" Unibody Early 2009 model to fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
17" Unibody Early 2009 ile çalışan parçalar:
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
SATA Optical Drive USB Cable
Connect an optical drive to your computer via USB with this part.
Unibody 8x SATA SuperDrive (Pre-Mid 2009)
Replace a malfunctioning or noisy optical drive.
MacBook Pro 17" Unibody (Early-Mid 2009) Used 8x SATA SuperDrive
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write
Cihaz Bilgisi
The MacBook Pro 17" Unibody, announced in January of 2009 has an aluminum case like the laptops before it, however the case is machined out of a single block of aluminum. The Unibody revision also introduced some new features for Apple laptops: dual video cards (one for regular use, one for graphics intensive applications), the Mini DisplayPort (which replaced the full-size DVI display connector), and larger hard drive and RAM capacities.
The most common repairs with a 17" MacBook Pro Unibody Early 2009 are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 17" Unibody (Early 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 17" Unibody Early 2009 repair guides for step-by-step instructions on how to make the fix.
