Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
  • MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
$219,99
$219,99
Ürün Detayı
Açıklama
Açıklama
Replace a damaged or malfunctioning 17" 1920 x 1200 LCD panel in your MacBook Pro 17" (Model A1261 Hi-Res) laptop.
This LCD panel can restore dead pixels, fix color bleeding, and eliminate lines in your display image as well as restore a dim or dead backlight.
Uyumluluk
Uyumluluk
  • 2.5 or 2.6 GHz (Model A1261) 17" MacBook Pros with 1920x1200 resolution
Teknik Özellikler
Teknik Özellikler
Resolution:
1920 x 1200
Diagonal Size:
17"
Uyumluluk
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
A1261 (EMC 2199) 2.5 GHz (Penryn)
A1261 (EMC 2199) 2.6 GHz (Penryn)
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
LCD was bad on a Macbook Pro A1261, ordered new screen.
Tamirim
Took everything apart only to realize I had ordered the wrong screen. Take note technicians, check your connectors on new parts before breaking everything down. And read everything about the part you are ordering carefully.
Önerim
iFixit team respond . . .
Kullanıcı avatarı
Sorunum
in quick succession I broke the LCD on the 17" Macbook Pro due to sloppy handling, and I shattered the glass front on my iPhone 5.
Both were not yet at the end of their life/usefulness so I decided to fix both myself.
Tamirim
things went pretty well. Finished both repairs in about 3 hours (while watching . . .
Kullanıcı avatarı
Sorunum
My 1 year old son had smashed my MacBook Pro screen and it was damaged for more then a year. I inquired at the local Apple Store and was shocked to know that the LED display would cost me around 1000$, it was so expensive that I thought I would never be able to repair it, until ifixit stepped in my . . .
Kullanıcı avatarı
Sorunum
Broken LCD on my macbook pro
Tamirim
Ordered part to fix. But it was damaged:( so i called got a replacement. Great CS by the way. Well.. I got ancy and started to take apart the laptop and found out that i ordered the wrong part.. Called back and the 1st replacement was already sent. So i ordered the right . . .
Daha fazla göster
