Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
  • MacBook Pro Unibody (Mid 2009-Mid 2012) Trackpad Mounting Screws
$9,99
$9,99
Ürün Detayı
Açıklama
Açıklama
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Pro Unibody (Mid 2009 - Mid 2012).
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
Includes:
  • Two trackpad springs
  • Eight tiny screws for securing the springs to the trackpad and the upper case
  • One trackpad button adjustment screw
Uyumluluk
Uyumluluk
  • MacBook Pro 13" Unibody A1278 Mid 2009 to Mid 2012
  • MacBook Pro 15" Unibody A1286 Mid 2009 to Mid 2012
Uyumluluk
MacBook Pro 13" Unibody Early 2011
A1278 (EMC 2419) 2.3 GHz
A1278 (EMC 2419) 2.7 GHz
MacBook Pro 13" Unibody Late 2011
A1278 (EMC 2555) 2.4 GHz
A1278 (EMC 2555) 2.8 GHz
MacBook Pro 13" Unibody Mid 2009
A1278 (EMC 2326) 2.26 GHz
A1278 (EMC 2326) 2.53 GHz
MacBook Pro 13" Unibody Mid 2010
A1278 (EMC 2351) 2.4 GHz
A1278 (EMC 2351) 2.66 GHz
MacBook Pro 13" Unibody Mid 2012
A1278 (EMC 2554) 2.5 GHz
A1278 (EMC 2554) 2.9 GHz
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
A1286 (EMC 2324) 2.53 GHz
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2009
A1286 (EMC 2325) 2.66 GHz
A1286 (EMC 2325) 2.8 GHz
A1286 (EMC 2325) 3.06 GHz
MacBook Pro 15" Unibody Mid 2010
A1286 (EMC 2353) 2.4 GHz
A1286 (EMC 2353) 2.53 GHz
A1286 (EMC 2353) 2.66 GHz
A1286 (EMC 2353) 2.8 GHz
MacBook Pro 15" Unibody Mid 2012
A1286 (EMC 2556) 2.3 GHz
A1286 (EMC 2556) 2.6 GHz
A1286 (EMC 2556) 2.7 GHz
8 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
The battery swelled/exploded and destroyed the trackpad - I had to replace the battery and the trackpad.
Tamirim
Simple. It took less than 30 minutes once I had all the parts.
Önerim
A few of the screws on the frame are extra long. I marked them on the back of the case - it was a lifesaver since it was several weeks . . .
Kullanıcı avatarı
Sorunum
I switched to a new aluminum frame top assembly since I cracked mine and a new adjustment screw for the trackpad was needed since I stripped the one in the broken body.
Tamirim
It was pretty simple after except the battery to forever to get off with a hair drier and credit card.
Önerim
Take your time go slow, I save . . .
