Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parts Mac MacBook Pro Headphone Jacks
Mağaza
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
MacBook Pro 13" (A2289, A2338, 2020) Headphone Jack / Used
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2020 model A2289 or A2338 13" MacBook Pro with two Thunderbolt ports.
$39,99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Headphone Jack / New / Black
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch Bar.
$17,99'den
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Headphone Jack / Gray / Used
Replace a damaged or corroded 3.5 mm audio jack or a malfunctioning microphone in a 2016 or 2017 model 13" MacBook Pro with Retina Display and function keys.
$24,99
MacBook Pro 13" Retina (Mid 2018-2020) Headphone Jack
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2018 or 2020 model 13" MacBook Pro with Retina Display.
$23,99
MacBook Pro 13" (A2159, 2019) Headphone Jack / Used
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2019 model A2159 13" MacBook Pro with two Thunderbolt ports.
$19,99
MacBook Pro 15" Retina (Mid 2012-Early 2013) Headphone Jack
Replace the 3.5 mm headphone jack.
$29,99
MacBook Pro 15" Retina (Late 2016-2017) Headphone Jack / New / Black
Replace a damaged or corroded 3.5 mm audio jack compatible with a Late 2016 or 2017 model 15" MacBook Pro Retina.
$24,99'den
MacBook Pro 15" Retina (Mid 2018-2019) and 16" (2019) Headphone Jack
Replace a damaged or corroded 3.5 mm audio jack compatible with a Mid 2018 or 2019 model 15" or a 2019 16" model MacBook Pro Retina.
$23,99'den
MacBook Pro 13" Retina Headphone Jack
Replace a dirty, corroded, or damaged 3.5 mm headphone jack in a 13" MacBook Pro with Retina Display.
$29,99
9 Üründen 1 - 9 arası ürün gösteriliyor
Cihaz Bilgisi
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
