Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parts Mac MacBook MacBook Retina 12" 2016 Wi-Fi Boards
Mağaza
Grab a toolkit for your MacBook Retina 12" 2016 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
MacBook 12" Retina (Early 2016-2017) Battery / New / Fix Kit
Replace a 5480 mAh battery compatible with MacBook 12" Retina (Early 2016-2017). 41.4 Watt Hours (Wh), 7.55 Volts (V).
$129,99'den
MacBook 12" Retina (Early 2016-2017) IPD Flex Cable
This cable connects the trackpad assembly to the logic board in a 2016 or 2017 model 12" Retina MacBook.
$19,99
MacBook 12" Retina (Early 2016-2017) Upper Case with Keyboard / Silver / New
Replace a dented or scratched upper case or malfunctioning keyboard for your Early 2016 or 2017 12" MacBook with this part. This assembly includes the upper case aluminum...
$159,99'den
MacBook 12" Retina (Early 2015-2017) Display Cable
Replace the display assembly flex cable.
$19,99
MacBook 12" Retina (Early 2016-2017) Trackpad / Silver
Replace the "Force Touch" trackpad for a 2016 or 2017 MacBook 12" Retina model A1534.
$69,99
MacBook 12" Retina (Early 2015-2017) Keyboard Flex Cable
This cable connects the keyboard to the trackpad assembly.
$14,99'den
MacBook 12" Retina (Early 2015-2017) Lower Case Screw Set / Silver
Replace the color coordinated exterior screws that hold the lower case panel in place.
$14,99
MacBook 12" Retina (Early 2016-2017) Lower Case / Silver
Replace a scratched or dented aluminum lower case on your Early 2016 or 2017 model MacBook 12" Retina.
$49,99
MacBook 12" Retina (Early 2015-2017) Audio Board / Gray
Replace the circuit assembly that supports the audio in/out port.
$39,99'den
MacBook 12" Retina (Early 2015-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly.
$9,99
20 Üründen 1 - 10 arası ürün gösteriliyor
Cihaz Bilgisi
Apple introduced this MacBook in April 2016, an updated version of the 2015 Retina MacBook, bearing the model number A1534 and the EMC number 2991. Available in four colors—silver, space grey, gold, and rose gold.
