Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Parts Mac MacBook MacBook Retina 12" 2017 Wi-Fi Boards
Mağaza
Grab a toolkit for your MacBook Retina 12" 2017 model and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Modelinizi bilmiyor musunuz? Mac cihazınıza ID atayın
MacBook 12" Retina (Early 2016-2017) USB-C Port Assembly
Replace a damaged or corroded USB-C port and the flex cable that attaches it to the logic board in an early 2016 or 2017 model 12" Retina MacBook.
$54,99
MacBook 12" Retina (Early 2016-2017) IPD Flex Cable
This cable connects the trackpad assembly to the logic board in a 2016 or 2017 model 12" Retina MacBook.
$19,99
MacBook 12" Retina (Early 2016-2017) Upper Case with Keyboard / Silver / New
Replace an upper case and keyboard compatible with the Early 2016 or 2017 model A1534 MacBook 12 inch laptop. Part #613-02547.
$199,99
MacBook 12" Retina (Early 2016-2017) Battery / New / Fix Kit
Replace a 5480 mAh battery compatible with MacBook 12" Retina (Early 2016-2017). 41.4 Watt Hours (Wh), 7.55 Volts (V).
$129,99'den
MacBook 12" Retina (Early 2016-2017) Trackpad / Silver
Replace the "Force Touch" trackpad for a 2016 or 2017 MacBook 12" Retina model A1534.
$69,99
MacBook 12" Retina (Early 2016-2017) Lower Case Assembly / A-Stock / Dark Gray
The lower case assembly includes the aluminum bottom case and the battery.
$89,99
MacBook 12" Retina (Early 2015-2017) Display Assembly / Premium / Silver
Replace a display compatible with the early 2015 to 2017 model A1534 12" Retina MacBook laptop. Includes the 2304 x 1440 pixel 12" LCD screen, aluminum case, 480p Facetim...
$369,99'den
MacBook 12" Retina (Early 2015-2017) Keyboard Flex Cable
This cable connects the keyboard to the trackpad assembly.
$14,99'den
MacBook 12" Retina (Early 2015-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly.
$9,99
MacBook 12" Retina (Early 2016-2017) Lower Case / Silver
Replace a scratched or dented aluminum lower case on your Early 2016 or 2017 model MacBook 12" Retina.
$49,99
19 Üründen 1 - 10 arası ürün gösteriliyor
Cihaz Bilgisi
Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
