PC2-5300 2 GB RAM Chip
  • PC2-5300 2 GB RAM Chip
$14,99
$14,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
A fast 2 GB RAM Chip for laptops
  • RAM is the cheapest and most effective speed upgrade you can do for your computer
  • Faster file save/loading, web browsing, gaming, and more.
  • Check our list of Macs, or your manual to get the right chip style.
Not
That "Warranty Void if Removed" sticker is wrong. Feel free to peel that sucker off, we'll still honor our warranty. Our RAM supplier made a mistake in printing, and we're fixing it in our next order of memory.
Uyumluluk
iMac Intel 17"
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
Mac Mini Model A1176
1.83 GHz (Core 2 Duo, Mid 2007)
2 GHz (Core 2 Duo)
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.5 GHz (Penryn)
2.6 GHz (Penryn)
6 cihaz daha göster
Onarım hikayeleri
Sorunum
Macbook was slow.
Tamirim
Couldn’t have been easier!
Önerim
The screws are really small and easy to loose. I used a small magnet to keep them in place.
Sorunum
The iMac needed a RAM upgrade before it could get Mac OSX 10.11 installed.
Tamirim
The repair went well. A simple screwdriver to remove the cover and then I inserted RAM into the empty slot.
Önerim
Removing the memory that was in the computer was difficult. This required a needle-nose pliers or something that can gr . . .
Sorunum
Changement de la RAM pour accélération des performances
Tamirim
Très bien.
Önerim
Prendre garde pour l'iMac blanc de bien remettre les clapets latéraux des barattes de RAM, avant de remettre les barrettes de RAM en position. Sinon vous ne pourrez plus les ressortir !
Sorunum
Someone here was throwing away an iMac because the screen was broken. I picked it and found I could replace the screen for $89. I let the original owner know, but he said it was too old for him. So I ordered some additional memory and an Hybrid SSD 1 TB drive as well. Yeah! I am now windowless at ho . . .
Sorunum
The machine only had 1 GB Ram installed
Tamirim
Easy : just follow the guide step by step
Önerim
Don't worry, just take your time to follow each step.
Sorunum
My harddrive broke so I had to change it.
Tamirim
The repair was REALLY easy and fast! No problems and now my computer is working better than ever because I put more memory in. I also got all my files and programs back because I had made backup with time machine. It was almost too easy:)
Önerim
I was taking the comp . . .
Sorunum
Old macmini on my shelf
Tamirim
Good repair except I didnt insert the RAM far enough. I just needed to push a bit harder to get it inserted properly.
My suggestion is to recommend to buyers of RAM is to buy two sticks. I had two slots in my mac mini and I only purchased one stick. Now that it's over I wish . . .
Sorunum
I had 2 gigs of RAM and needed more speed for my 2008 Mac desktop. A friend of mine that's a whiz with Macs sent me your link. I ordered 2 2GB RAM chips, printed out your directions for installation and it was a snap.
Tamirim
It went without a hitch. It was extremely easy. Thank you!!!!!! Now my computer . . .
Sorunum
First time replacing the RAM in a Macbook and thank god! It need it!
Tamirim
It was smooth and simple! Take the battery off then punch out the old and swap with the new.
Önerim
Just the usual: discharge any electric charge, disconnect the battery and power source, get to work and get back at it!
Sorunum
Yes
Tamirim
Good
Önerim
No
Daha fazla göster
