PC3-10600 8 GB RAM Chip
  • PC3-10600 8 GB RAM Chip
$69,99
$69,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Ürün Detayı
Açıklama
Açıklama
Adding RAM to your computer can provide a significant performance boost.
Please Note: the Mid 2010 21.5" iMacs (EMC 2389) & 27" iMacs (EMC 2390) with the Core i3 and the Mid 2011 27" iMacs (EMC 2429) with the Core i5 can only accept up to 4 of the 4 GB chips. This RAM will not work in these machines.
Uyumluluk
iMac Intel 21.5" EMC 2428
2.5 GHz (Mid 2011)
2.7 GHz (Mid 2011)
2.8 GHz (Mid 2011)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.6 GHz (Mid 2010)
iMac Intel 27" EMC 2429
3.4 GHz (Mid 2011)
Mac Mini Mid 2011
2 GHz (Quad i7)
2.3 GHz (Dual i5)
2.5 GHz (Dual i5)
2.7 GHz (Dual i7)
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 17" Unibody
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
6 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
My hard drive went out on my late 2011 mbp but I didn’t want to spend money on a new laptop so I bought an ssd drive and I also decided to upgrade the ram. I bought a refurbished memory ram on ifixit.com because I didn’t want to spend much money plus they offer life time warranty on it and let m . . .
Kullanıcı avatarı
Sorunum
Upgrade RAM
Tamirim
SIMPLE
Önerim
Follow the instructions and make sure you have the necessary tools
Kullanıcı avatarı
Sorunum
Just not enough ram for my taste
Tamirim
amazing
Önerim
Replacing the ram in the earlier model macs can be the easiest of fixes. It really did only take me 30 seconds to replace the ram.
Kullanıcı avatarı
Sorunum
Super slow beachballing crashing
Tamirim
Incredibly easy to do ---- changed out the two 2GB RAM for two 8GB RAM in under 15 min.!
Önerim
"Below Average" now overall on EtreCheck instead of "Failed" b/c back-up disk is too small. Can't do anything about that with this old machine. Very happy I can keep using it . . .
Kullanıcı avatarı
Sorunum
Need for speed...I typically have 5+ windows open all the time so speed suffers and the 8GB the laptop came with was slowing down. The price from iFixit was good, warranty great, and the directions simple.
Tamirim
Almost without a hitch. I have oversized fingers (size 13.5 wedding band) so it took a little e . . .
Kullanıcı avatarı
Sorunum
Just wanted to max-out the RAM
Tamirim
No problems
Önerim
Keep up with the screws, make sure you reinstall the correct screws in the correct holes.
Kullanıcı avatarı
Sorunum
My MacBook was getting too slow.
Tamirim
It was such an easy task, finished it in less than a min after opening it up.
Önerim
Big improvement than what I was experiencing before.
Kullanıcı avatarı
Sorunum
J'avais un problème avec la capacité de la mémoire vive de mon MacBook Pro. Je suis passé de 4G à 16G de mémoire vive. Il réagit très bien.
Jean-Robert Grenier
Tamirim
Très bien
Önerim
Tout était très bien expliqué.
Kullanıcı avatarı
Sorunum
Just a slow processing computer ever since yosemite. 4 mb ram is not enough and 500gb hard drive not enough space.
Tamirim
Easy, I figured while had it open a new SSDHD was nessery along with 16gb ram. With the great instructions, I had both done in about 1/2 hour once i started.
Önerim
Read all of the instructi . . .
Kullanıcı avatarı
Sorunum
The computer was incredibly slow and was running out of free space.
Tamirim
The repair was quite simple and intuitive. According to the comments, I didn't disconnect all the wires and the repair was still really easy.
Önerim
You can add thin pieces of foam to reduce HD vibrations.
Daha fazla göster
