Unibody (Post-Early 2009) 8x SATA SuperDrive
  • Unibody (Post-Early 2009) 8x SATA SuperDrive / Used
Fully functional
Koşul: Kullanılmış
$49,99
$49,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
Replace a broken or damaged SuperDrive for your Post-Early 2009 MacBook Unibody with this part. This part does not include the metal mounting bracket and orange ribbon cable.
Not
This optical drive has different mounting holes for screws. '''If you do not have a Unibody made after the Early 2009 release, this drive will not work in your machine.
Uyumluluk
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
MacBook Pro 17" Unibody
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
9 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
Because it was broke and destroying DVD's
Tamirim
Very well
Önerim
Nope everything worked well
Kullanıcı avatarı
Sorunum
Ordered an optical drive and HD cable from iFixit to repair two different MacBook Pros.
Tamirim
Both parts I ordered fit perfectly and fixed both machines.
Önerim
The repair guides are great and the parts I ordered are a great alternative to going with Apple repair parts.
Kullanıcı avatarı
Sorunum
It used to be my wife's mbp and I gave it to her in our wedding days , but she broke the front glass and super drive wont work ..ect
Tamirim
I replaced front glass , super drive, battery, hard drive with SSDH and I upgraded memory from three to eight .
Önerim
Be careful with opening cables specially the smaller one . . .
Kullanıcı avatarı
Sorunum
Optical drives are almost vestigial, but not quite, particularly if you want to play older titles, like Tomb Raider Anniversary.
Tamirim
The repair went great! The parts arrived promptly and the Android app helped me install it step-by-step. Now I can get back to raiding those tombs. Cheers!
Önerim
Keep up the good . . .
Kullanıcı avatarı
Sorunum
Superdrive was acting up. I ordered a replacement from ifixit. Within a few days my order arrived. Installation took about 30 minutes, and the replacement worked perfectly.
Tamirim
Easy...thanks to the detailed guide on ifixit.
Önerim
Just follow the directions. Keep all your screws organized and in order. There are . . .
Kullanıcı avatarı
Sorunum
My wife's MacBook Pro optical drive was spinning but it wouldn't read anything. Since I do Technology Support for our school district I had taken apart MacBook Pros before, but had never replaced an optical drive before.
Tamirim
With the fabulous instructions on iFixit. com it was VERY easy. Put it back . . .
Kullanıcı avatarı
Sorunum
The trackpad on my wife's mid 09 MBP was not recognizing the physical click, for almost two years. The optical drive was also not functioning for over a year. We have three kids and they sometimes move faster than we can take things away from them.
Tamirim
Due to the step by step guides the repair was easy . . .
Kullanıcı avatarı
Sorunum
DVD quit...hard drive way too small!!!!
Friend was afraid to dig in...So I jumped in...
Tamirim
Remove the screws...pull it apart...put it back together...wala!!!
All works like a champ!!!
Önerim
Go slow and don't over tighten anything...snug is cool.
Kullanıcı avatarı
Sorunum
Unibody 8x SATA SuperDrive had expired and needed replacing.
Tamirim
Went smoothly.
Önerim
Use pencil marks to mark where long screws go when removing bottom of laptop. They easily wipe off when done.
Kullanıcı avatarı
Sorunum
Dead Superdrive
Tamirim
Just fine!
Ordered the drive on a monday at eleven am. Got the Fedex package at eleven Wednesday. And I live in Stockholm, Sweden.
Önerim
Simple repair. And You don't have to take the battery out so You don't need the pentalobe tool.
Daha fazla göster
