iMac G5/Intel Power Supply
  • iMac G5/Intel Power Supply
$129,99
$129,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
Replace that old Power Supply!
Sir Francis Bacon contended that "knowledge is power." Clearly he never tested his theory by reading an encyclopedia to a computer with a dead power supply. Save your breath and empower your iMac G5/Intel the sure-fire way with our replacement power supply.
NOTE: This power supply is not compatible with EMC No. 2124 (Apple Part #661-4018).
Uyumluluk
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
1 cihaz daha göster
Onarım hikayeleri
Sorunum
The power supply died.
Tamirim
The guide was spot on. There are a lot of fiddly bits with adhesive that are a pain, but can be dealt with.
The new supply dropped right in and works great. My old iMac is still running just fine.
Önerim
I had a couple of very strong magnets. They make getting the bezel off a very eas . . .
Sorunum
The IMac G5 would no longer turn on after being handed down to my two adult children.
Tamirim
I first got the idea of trying to fix it rather than throw it away from your YouTube video. I then went to the IFixIt web site and saw the tutorial on how to replace the power supply. Having never attempted any comp . . .
Sorunum
When I am away from home for an extended period I usually power off my iMac and disconnect the power. After returning home from a long weekend recently I reconnected the power and nothing, no light no sound, no smell. After multiple attempts trying different power sources and power cords I was sat . . .
Sorunum
The computer is ten years old and still has a bright screen and I recently upgraded the memory to the maximum available. In other words, other than being a bit slow it was in perfect working order and was the computer used in the shop so I needed to replace it or fix it. I gambled and won...for $1 . . .
Sorunum
My PSU in my 2006 iMac g5 burnt out 3 years ago while I was plugging it in. There was a tiny spark and the thing wouldn't turn on. It was too old to get it repaired by Apple.
Tamirim
It took about an hour to get disassembled. Once I did that, I promptly realized there was manufacturer error and had to call a . . .
Sorunum
Guasto del trasformatore.
L'assistenza ufficiale Apple non fornisce più il pezzo di ricambio.
L'iMac per loro era spacciato.
Tamirim
Bene, ho seguito passo passo la procedura guidata e sono riuscito a sostituire il trasformatore.... il Mac non è esploso.
Önerim
Io non avevo mai fatto un'operazione come sostituire . . .
Sorunum
Figured the problem had to be the power supply. Decided to try to fix it because of your online tutorial.
Tamirim
Repair went very well, following the instructions
Önerim
Smaller fingers!!
Sorunum
Power supply out of order on Imac 20''
Tamirim
Great, no problem
The Imac works well now with his new power supply !
Önerim
very simple to do
Sorunum
2 coupures de courant et mon bon vieux imac ne démarre plus. Encéphalogramme plat. SAV Apple : on ne répare plus; il faut le remplacer 1299 €. Cher pour une alimentation!!!! et puis M6 dimanche soir sur capital et 5 jours après imac ressuscité (alimentation commandé sur ifixit).
Tamirim
Sur des roule . . .
Sorunum
The computer was not booting. It would spin up the CD and make a few disk noises, but nothing else. After closer inspection and gaining familiarity with the hardware (more on this later), I noticed that only the first 2 debug LEDs (middle of logic board) were lighting up and the white "status" LED i . . .
Daha fazla göster
