Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
  • iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
$139,99
$139,99
Ürün Detayı
Açıklama
Açıklama
Bring your iMac back to life!
Uyumluluk
Uyumluluk
  • 2.4 (EMC No. 2210) and 2.66 (EMC No. 2210) GHz 20" Intel iMacs
Teknik Özellikler
Teknik Özellikler
Part #:
661-4670 , 614-0438
Kurulum Videosu
Uyumluluk
iMac Intel 20" EMC 2133 and 2210
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
Onarım hikayeleri
Kullanıcı avatarı
Chee Yong Koo's Story Photo #364177
Sorunum
Power supply went unserviceable after 5 years of usage.
Tamirim
it definitely took an hour or so but the repair was slow, steady but smooth.
Önerim
Current guide was good enough however major improvements could have been made in the video where certain parts of "disconnecting cables /parts " of hardware made cleared . . .
Kullanıcı avatarı
Sorunum
I woke up one morning to find a dead iMac (2008 20" 2.66 ghz), and then noticed the house power had gone out during the night. I like the iMac, and it synchs with my iPhone, so I decided to repair it. Also, it had 13,000 family photos going back to 2003.
Tamirim
The repair went smoothly, even with help from . . .
Kullanıcı avatarı
Sorunum
My wife has a 20" Intel iMac (EMC No. 2210) which had slowed to a crawl and eventually failed to boot. I have always had PC's and wasn't shy about swapping out hard drives and performing basic hardware repairs or upgrades. I wasn't eager to go out and spend a couple grand on another Apple computer . . .
Kullanıcı avatarı
Sorunum
the iphone had a broken glass display was working.The imac mod a1224 emc nr 2210 stopped working for a friend in the music aranger and musican.powersuply was the problem i found out with help fom your informative site and videos.worked with electroniks for 30 years.
Tamirim
The iphone 5s i have bougth a disp . . .
Kullanıcı avatarı
Sorunum
Power supply burned out during electrical storm. Insurance declined to fix or replace as machine no longer supported by Apple. Insurance company paid me $250 which more than covered the cost of a replacement power supply from iFixit.
Tamirim
No problems, easy-peasy, with instructions from iFixit lady on yout . . .
Kullanıcı avatarı
Sorunum
20" iMac EMC 2210: Overheating power supply caused a slight discoloration of the LCD screen on the corner in front of the power supply. It was also causing intermittent short term cut off of power which caused problems with the Hard Drive, That was the reason it was brought in for service.
Tamirim
Used the . . .
Kullanıcı avatarı
Sorunum
We had a brownout and the iMac shut itself off. It wouldn't turn back on. I unplugged it from the wall for thirty seconds and it turned on and shut itself off again. It would not run longer than 5 minutes. So I ordered the power supply.
Tamirim
The repair went smoothly. The only trouble I had with the disass . . .
Kullanıcı avatarı
Sorunum
My 20" iMac simply stopped working one evening recently while I was streaming music to my Apple TV. I did a little research and found there were diagnostic lights on the bottom. I saw light #1 (which indicates if the unit is getting power) was blinking and "guessed" the power supply had gone bad. . . .
Kullanıcı avatarı
Sorunum
My desktop iMac suddenly does not turn on any more - I tried everything I can check from internet sources, from checking power cables to reseting power management, all unsuccessful. Thanks to an iFixit guide and comments, I checked the power supply unit inside iMac and appeared to be the problem, z . . .
Kullanıcı avatarı
Sorunum
My iMac started acting funky. At first it just did not want to start up after a power failure. Sometimes it would just sit there and a few hours later power on. Strange very strange. Finally, it simply refused to power up. No chimes, no fan noise, no nothing. Just a door stop. What could it b . . .
Daha fazla göster
