Fix Your Stuff
Right to Repair
Parts & Tools
iMac Intel 21.5" (2012-2019) Adhesive Strips
  • iMac Intel 21.5" (2012-2019) Adhesive Strips / Fix Kit
  • iMac Intel 21.5" (2012-2019) Adhesive Strips / Part Only
$19,99
$19,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
This complete set of replacement adhesive strips are specifically cut to fit 21.5" iMacs from Late 2012 through 2019. The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
The unique design of the 21.5" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Uyumluluk
Uyumluluk
  • iMac Intel 21.5" A1418 Late 2012 to 2019
  • EMC 2544, 2545, 2638, 2742, 2805, 2889, 2833, 3068, 3069, 3195
Uyumluluk
iMac Intel 21.5" EMC 2544
2.7 GHz (Late 2012)
2.9 GHz (Late 2012)
3.1 GHz (Late 2012)
iMac Intel 21.5" EMC 2545 (Edu)
3.3 GHz (Early 2013 Edu)
iMac Intel 21.5" EMC 2638 & EMC 2742
EMC 2638 2.7 GHz (Late 2013)
EMC 2742 2.9 GHz (Late 2013)
EMC 2742 3.1 GHz (Late 2013)
iMac Intel 21.5" EMC 2805
1.4 GHz (Mid 2014)
iMac Intel 21.5" EMC 2889
1.6 GHz (Late 2015)
2.8 GHz (Late 2015)
iMac Intel 21.5" EMC 3068
EMC 3068 non 4K 2.3 GHz
iMac Intel 21.5" Retina 4K Display 2015
EMC 2833 3.1 GHz
EMC 2833 3.3 GHz
iMac Intel 21.5" Retina 4K Display 2017
EMC 3069 3.0 GHz
EMC 3069 3.4 GHz
EMC 3069 3.6 GHz
iMac Intel 21.5" Retina 4K Display 2019
EMC 3195 3.0 GHz
EMC 3195 3.2 GHz
EMC 3195 3.6 GHz
6 cihaz daha göster
Müşteri Yorumları
