Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
iMac Intel 21.5" (2012-2019) Adhesive Strips
  • iMac Intel 21.5" (2012-2019) Adhesive Strips / Fix Kit
  • iMac Intel 21.5" (2012-2019) Adhesive Strips / Part Only
$19,99
$19,99
Ürün Detayı
Açıklama
Açıklama
Replace a complete set of replacement adhesive strips specifically cut to fit 21.5" Late 2012 to 2019 iMacs.
  • The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
The unique design of the 21.5" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Uyumluluk
Uyumluluk
  • iMac Intel 21.5" A1418 and A2116 Late 2012 to 2019
  • EMC 2544, 2545, 2638, 2742, 2805, 2889, 2833, 3068, 3069, 3195
Uyumluluk
iMac Intel 21.5" EMC 2544
A1418 Late 2012 iMac13,1 2.7 GHz
A1418 Late 2012 iMac13,1 2.9 GHz
A1418 Late 2012 iMac13,1 3.1 GHz
iMac Intel 21.5" EMC 2545 Early 2013 (Edu)
A1418 Early 2013 Edu iMac13,1 3.3 GHz
iMac Intel 21.5" EMC 2638 & EMC 2742 Late 2013
A1418 EMC 2638 Late 2013 iMac14,1 2.7 GHz
A1418 EMC 2742 Late 2013 iMac14,3 2.9 GHz
A1418 EMC 2742 Late 2013 iMac14,3 3.1 GHz
iMac Intel 21.5" EMC 2805
A1418 Mid 2014 iMac14,4 1.4 GHz
iMac Intel 21.5" EMC 2889
A1418 Late 2015 iMac16,1 1.6 GHz
A1418 Late 2015 iMac16,1 2.8 GHz
iMac Intel 21.5" EMC 3068
A1418 non 4K Mid 2017 iMac18,1 2.3 GHz
iMac Intel 21.5" Retina 4K Display 2015
A1418 EMC 2833 iMac16,2 3.1 GHz
A1418 EMC 2833 iMac16,2 3.3 GHz
iMac Intel 21.5" Retina 4K Display 2017
A1418 EMC 3069 iMac18,2 3.0 GHz
A1418 EMC 3069 iMac18,2 3.4 GHz
A1418 EMC 3069 iMac18,2 3.6 GHz
iMac Intel 21.5" Retina 4K Display 2019
A2116 EMC 3195 iMac19,2 3.0 GHz
A2116 EMC 3195 iMac19,2 3.2 GHz
A2116 EMC 3195 iMac19,2 3.6 GHz
6 cihaz daha göster
Müşteri Yorumları
