iMac Intel 27" (2012-2019) Adhesive Strips
  • iMac Intel 27" (2012-2019) Adhesive Strips / Fix Kit
  • iMac Intel 27" (2012-2019) Adhesive Strips / Part Only
$19,99
$19,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Android Tamir Setleri
Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
Hemen Alışveriş Yapın
Ürün Detayı
Açıklama
Açıklama
This complete set of replacement adhesive strips is specifically cut to be compatible with 27" iMacs from Late 2012 to 2019 and the 2017 iMac Pro. The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
The unique design of the 27" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Kit İçeriği
Kit İçeriği
Uyumluluk
Uyumluluk
  • iMac Intel 27" A1419 Late 2012 to Mid 2017
  • iMac Intel 27" A2115 2019
  • EMC 2546, 2639, 2806, 2834, 3070, 3194
  • iMac Pro A1862 Late 2017 EMC 3144
Teknik Özellikler
Teknik Özellikler
Part #:
076-1444
Uyumluluk
iMac Intel 27" Retina 5K Display (Mid 2017)
EMC 3070 3.4 GHz
EMC 3070 3.5 GHz
EMC 3070 3.8 GHz
EMC 3070 4.2 GHz
iMac Intel 27" EMC 2546
2.9 GHz (Late 2012)
3.2 GHz (Late 2012)
3.4 GHz (Late 2012)
iMac Intel 27" EMC 2639
3.2 GHz (Late 2013)
3.4 GHz (Late 2013)
3.5 GHz (Late 2013)
iMac Intel 27" Retina 5K Display (Late 2014 & 2015)
EMC 2806 3.3 GHz (Mid 2015)
EMC 2806 3.5 GHz (Late 2014)
EMC 2806 4.0 GHz (Late 2014)
EMC 2834 3.2 GHz (Late 2015)
EMC 2834 3.3 GHz (Late 2015)
EMC 2834 4.0 GHz (Late 2015)
iMac Intel 27" Retina 5K Display 2019
EMC 3194 3.0 GHz
EMC 3194 3.1 GHz
EMC 3194 3.6 GHz
EMC 3194 3.7 GHz
iMac Pro
EMC 3144 2.3 GHz (Late 2017)
EMC 3144 2.5 GHz (Late 2017)
EMC 3144 3.0 GHz (Late 2017)
EMC 3144 3.2 GHz (Late 2017)
3 cihaz daha göster
Müşteri Yorumları
