Anti-Static Mat
  • Anti-Static Mat / 12" x 20" / New
  • Anti-Static Mat / 20" x 24" / New
  • Anti-Static Mat / 70 x 100 cm / New
Anti-Static Mat
The perfect size for phone and small electronics repair.
$24,99
$24,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Ürün Detayı
Açıklama
Açıklama
The best protection against ESD.
  • Ground yourself and your work surface to prevent damage from electrostatic discharge (ESD).
  • Various sizes to fit any work station.
  • Learn more about how to avoid turning your beloved devices into expensive paperweights in our full post or the video below.
  • For a less-stationary alternative to this anti-static mat, see the portable anti-static mat.
Ürün Videosu
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
Problema display iPhone
Tamirim
Estuvo excelente
Önerim
No
Kullanıcı avatarı
Sorunum
Broken Screen
Tamirim
Straight forward. Worked the first time.
Önerim
Use a clean white area like a anti-static mat. A head magnifier helps. The assembly requires patience as the screws are very small and hard for the average person to work with.
Kullanıcı avatarı
Sorunum
I am in school getting my A+, and this Pro Tech Toolkit has everything that I need to get started.
Tamirim
New student and needed to get a toolkit. Mike Myers referred me to this company and it is great.
Önerim
Great company and great products.
Kullanıcı avatarı
Sorunum
I recently installed OSX Yosemite on my Mid-2010 MacBook Pro. It had been starting to slow down since Mavericks but was slightly more noticeable again, now that I have Yosemite. So I decided it was time to invest a little to speed 'er up!
Tamirim
I bought a little more gear than I needed as i'm planning a f . . .
Kullanıcı avatarı
Sorunum
The second hard drive for my MacMini Server crashed. Hopefully the OS was on the first HD so the Mac was still booting fine.
Tamirim
It was a bit challenging with a process with this many steps but every step was quite easy to do.
The hardest part was fitting the first HD in place. Like said in the g . . .
Kullanıcı avatarı
Sorunum
My phone got wet after a swim in a river & a waterproof case failure. The LED flash would stay on even when I shut down the phone. Also, the phone would pretend it was always plugged into a dock, so the volume buttons would not work & I could not get any sound from videos and music.
Tamirim
It was pretty e . . .
Kullanıcı avatarı
Sorunum
I'm the only IT Analyst at my site and I have to be the hands to fix everything from software, account access, to hardware support. I also have to travel to other sites to help out and this tool kit goes with me every time. My kit mainly includes the pro kit, ratchet, magnetic mat, and, etc. My f . . .
Kullanıcı avatarı
Sorunum
My Galaxy S3 would intermittently (once or twice a day) lose the cell signal.
Tamirim
Being optimistic, I ordered your tools and tried to find the problem. I opened the phone and removed the first inner plate, and the shield on the SIM card fell out into my hand!
I wedged it back into its clips, put the scr . . .
Kullanıcı avatarı
Sorunum
I quit trusting "Geniuses".
Tamirim
I replaced the airport card, but that didn't solve the problem.
Önerim
Easy fix if it's the actual problem.
Kullanıcı avatarı
Sorunum
Track Pad was unresponsive and would not click.
Tamirim
Very simple repair. Remove lower case and battery and its just a matter of screwing the new one in.
Önerim
Be sure to check the adjustment Torx screw right next to the track pad for proper click and sensitivity. The original repair guide did not include this st . . .
Daha fazla göster
