Detailing Brush
  • Detailing Brush / Nylon
  • Detailing Brush / Brass
Detailing Brush
$2,99
$2,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
No more worn out toothbrushes with bent bristles, these economic professional tools will do the job faster and better, fitting into more places, and don't require handle bending pressure to do a good job. These bristles are ready to scrub and clean with minimal effort.
This double ended brush will fit in tight spaces and quickly cleans up battery acid damage, residue from spills, corrosion from water damage, dust, and thermal paste residue.
Not
This brush is safe for most applications, but is not an official "ESD safe" tool.
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
Water damage on a macbook pro.
There was a dime sized bit of corrosion on the logic board and it would not turn on.
Tamirim
Pulled the back off, unhooked the battery, stogged the corroded bits with a really soft brush and alcohol. Let it dry, put it back together and it turned back on.
Önerim
Be brave...
Kullanıcı avatarı
Sorunum
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
Tamirim
Repairs go a lot quicker with the right tools.
Önerim
Make sure you have the ri . . .
Kullanıcı avatarı
Sorunum
Bass from speakers just come out as muddled.
Tamirim
Removed without much trouble.
Önerim
The original screws securing the sub-woofer strips quit easily. Pay attention when removing them. I had to discard one screw I stripped. Luckily I could remove them by forcing the screwdriver into the screw to create new indent . . .
Kullanıcı avatarı
Sorunum
Silly Tri-Tip screwdrivers, lucky ifixit came to the rescue!
Tamirim
Excellently
Önerim
Make sure you order the right battery from Amazon, it's too bad that ifixit doesn't stock batteries for newer Macbook Pro's
Kullanıcı avatarı
Sorunum
Just needed some more tools for opening Apple Mac's, Getting out laptop screws that have had there heads destroyed and the magnetic project mat for the laptop screws.
Tamirim
Always good
Önerim
By the right tools for the right job and it always easier.
Daha fazla göster
Bu ürünü satın alan müşteriler aynı zamanda aşağıdaki ürünleri de satın aldı
