Essential Electronics Toolkit
  • Essential Electronics Toolkit / New
  • 360°
360
Limit 5 per customer.
$19.99
$19.99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
Our most economical do-everything toolkit. The Essential Electronics Toolkit is what you need for the most essential electronics repairs—like screen and battery swaps—and everything you need for most household DIY fixes.
Get started in electronics repair with all the bits and precision tools to handle your most urgent screen breaks and battery swaps. Or simply upgrade your home DIY toolkit with what you need to service door knobs, home appliances, eyeglasses, and more.
Toolkit Includes
Onarım hikayeleri
Kullanıcı avatarı
Sean Lichtenstein's Story Photo #1330869
Sorunum
Cracked/Smashed IPhone 6S screen
Tamirim
It went well! A little more difficult than I expeted but the guides were a fundamental help with this repair- I would not have been able to complete it without them!
It was a bit tricky getting the Home button in place as well as the earpiece speaker and camera- but . . .
Kullanıcı avatarı
Sorunum
power brick went out in the XBox
Tamirim
The repair was fairly easy. Although the only issues i had was not putting bottom metal cover on before i closed it up. So had to take apart. Then put back together. Then realized i let a few screws out. haha so took apart again installed screws and put back together, . . .
Kullanıcı avatarı
Sorunum
OEM battery was no longer holding charge
Tamirim
Awesome! ifixit tool kit was a huge help
Önerim
Don’t attempt this without a iPod opening tool.
Kullanıcı avatarı
Sorunum
Battery was old and drained quickly.
Tamirim
It didn’t take 45 min. 25 is more accurate.
Önerim
Instead of trying to pull the glue, heat it up for a minute and the battery comes right off.
Kullanıcı avatarı
Sorunum
I had a guy from Facebook come and ask me to repair his iPhone 6 Plus screen because he saw a recent post that showed I can do that
Tamirim
It went flawlessly
Önerim
I know by heart the way around an iPhone but if you don’t, and not many people do, I suggest to use their instructional videos
Kullanıcı avatarı
Sorunum
It had the 3 beep of death. I purchased 2, 8s of ram for a total of 16, however. It would not allow this. So ended up with 10gb. Initially I thought I had a bad top ram slot. But the 2gb took. But had to put them in one at a time to test them. I truly would not wanted to replace the logic board. S . . .
Kullanıcı avatarı
Sorunum
I replaced the battery, fan, and right speaker/subwoofer
Tamirim
Took my time and reviewed videos over and over. Everything went smoothly.
Önerim
for images, I would show the before and after shot of how to remove certain connections. I didn't know how to remove a certain piece from your website, but found out fro . . .
Kullanıcı avatarı
Sorunum
My MacBook Pro Early Rubber Feet has left and I was replace it with MBP Rubber Feet that i was buy on iFixit Store. I buy Essential Electronics Toolkits to do this.
Tamirim
First, i replace botoom case my MacBook Pro and then replace 4 rubber feet.
Just do it.
Önerim
You don't need adhesive 'cause iFixit MBP Rubber . . .
Kullanıcı avatarı
Sorunum
Still using the original battery in 2018 so decided it was time.
Tamirim
Replacement went smoothly -- except for the enclosed tools. I recommend purchasing the toolkit to avoid stripping the screws.
Önerim
The four screwdrivers are really just toys; please either spring for a better set of just do away with them.
Kullanıcı avatarı
Sorunum
Hard drive died. My first delve into computer guts. Drive seemed fine, head not stuck, but made clicking noise. Decided I wouldn't be able to recover. Maybe circuit board... Bought Evo 256Gig SSD and while looking around the delightful ifixit site, discovered the discussions about upgrading the . . .
Daha fazla göster
