Gamebit 4.5mm
  • Gamebit 4.5mm
  • Gamebit 4.5mm / Japan / Fixed Blade
Gamebit 4.5mm
$24,99
$24,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
Used in many video game consoles and other devices, this type of fastener is most commonly called by it's incorrect nickname of 4.5mm Gamebit. The correct fastener type and size is 4.6mm Line Head Screw.
Until now, only poor quality 1/4" drive "Gamebits" have been available in the USA, that are unable to reach the recessed screws found on some consoles.
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
Front glass was shattered after a drop. Touch still worked but was annoying.
Tamirim
Followed the guide and repair was easy. Some screws inside were missing from a bad repair job before so it took a little longer than expected but everything went smoothly.
Önerim
Be sure to watch out for the digitizer cable getting . . .
Kullanıcı avatarı
Sorunum
A friend asked me to make an upgrade to his Nintendo GameCube. He asked for an addition of a "Xeno-GC" driver chip.
Tamirim
The GameCube case needs to be opened with a proprietary "GameBit" driver. Aside from that tool, I only needed to use two smaller Phillips drivers to disassemble every major assembly wit . . .
Kullanıcı avatarı
Sorunum
i had to open a gamecube that had a fan problem. FIXED!
Tamirim
Smoothly, no problem with those superb gamebits
Önerim
Get your stuff on IFIXIT because people who got equiped with IFIXIT fix like PRO!
Kullanıcı avatarı
Sorunum
MY SON WANTED TO PLAY IT AGAIN AS HE FOUND MY BOX WITH SEGA GAME GEAR, ATARI LYNX AND THE VIRTUAL BOY IN IT. DON'T LEAVE BATTERIES IN YOUR ELECTRONICS AND PUT THEM INTO STORAGE! YOU'LL LEARN HOW TO CLEAN LEAKY BATTERY SPLOOGE REALLY GOOD.
Tamirim
FINE, EXTREMELY SIMPLE REPAIR. REMOVE 2 FLEXIBLE RIBBONS AND . . .
Kullanıcı avatarı
Sorunum
I got this for my gamecube just so i could swap the casing. I have the old gamecube with the digital av out but the console itself looked bad and had scratches. I had another one so i swapped the insides and now my gamecube looks amazing.
Tamirim
The gamebit worked flawlessly and with ease. The quality feel . . .
Kullanıcı avatarı
Sorunum
hey guys you've been great to deal with,no big repair going on just yet trying to teach myself as much as i can first and this site is very helpful,I am now and always will be a loyal customer
Tamirim
no repair just using this site and it friends to learn and try to apply to things in the future,this is an e . . .
Daha fazla göster
Bu ürünü satın alan müşteriler aynı zamanda aşağıdaki ürünleri de satın aldı
