Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
JIS Driver Set
  • JIS Driver Set
JIS Driver Set
$19,99
$19,99
Ürün Detayı
Açıklama
Açıklama
This is our set of hard to find JIS drivers in #000 (2mm), #00 (2.5mm), #0 (3mm), #1 (4mm) sizes. Japanese Industrial Standard (JIS) screws are very common in personal electronics from digital cameras to RC Helicopters. JIS screws are often marked by a single dimple pressed into the screw head.
JIS screws are not designed to "cam-out" or strip the head when overtightened like a Phillips screw, and can be damaged if a Phillips driver is used. JIS drivers can be used in both JIS and Phillips screws with no damage.
This made in the USA set of 4 JIS drivers matches our Professional line of screwdrivers and has ergonomic swivel top ESD safe handles.
Müşteri Yorumları
