Mac mini Logic Board Removal Tool
  • Mac mini Logic Board Removal Tool / Stainless Steel
$4,99
$4,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
  • Simple tool pries the logic board free to allow access to the hard drive in 2010 to 2014 Mac minis.
  • Custom iFixit version is nearly indistinguishable from Apple's official logic board removal tool.
Uyumluluk
Mac Mini Late 2012
2.3 GHz (Quad i7)
2.5 GHz (Dual i5)
2.6 GHz (Quad i7)
Mac Mini Late 2014
1.4 GHz (Dual i5)
2.6 GHz (Dual i5)
2.8 GHz (Dual i5)
3.0 GHz (Dual i7)
Mac Mini Mid 2010
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
Mac Mini Mid 2011
2 GHz (Quad i7)
2.3 GHz (Dual i5)
2.5 GHz (Dual i5)
2.7 GHz (Dual i7)
1 cihaz daha göster
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
Upgrade to SSD
Tamirim
Found out the hard way you need to reformat the SSD before installing in the Mac mini. Otherwise it went fine.
Önerim
Note in the guide to reformat the SSD before installing into the Mac mini
Kullanıcı avatarı
Sorunum
replaced HDD with SSD
Tamirim
did not need tool to remove logic board but screen did not fit back could not use one screw
Önerim
take risks but use good tools
Kullanıcı avatarı
Sorunum
One day my Mac Mini would not wake up. Leading up to this it was acting a bit unreliable.
Tamirim
I started with first unplugging the power supply from the logic board and measuring the power supply output with a multi-meter to ensure that was not the issue. It puts out a simple 12V to the logic board so i . . .
Kullanıcı avatarı
Sorunum
Not a problem but an upgrade. A friend of a friend was in the market for a new computer and I convinced him to buy a Mac. A large selling point was the ability to purchase an older Mac and install a second drive and install Windows on it in the off chance he'd ever want to go back to it.
Tamirim
"Repair" its . . .
Kullanıcı avatarı
Sorunum
My original 500GB hard drive was very SLOW .
Tamirim
Super easy. Followed the instructions provided on ifixit.com, easy to follow and step by step. I was up and running within an hour. Now my Mac Mini is FAST!!
Önerim
1. Backup to Time Machine First - restore is fast and easy.
2. Follow the instructions for a co . . .
Kullanıcı avatarı
Sorunum
The hard drive was to slow - change it to a SSD
Tamirim
Followed the repair guid for harddisk installation, and the guide was really helpful.
Önerim
Take your time and read the guid carefully. If you do, you will not go wrong
Kullanıcı avatarı
Sorunum
I was receiving a SMART report of imminent failure, so I replaced it with a Crucial MX300 SSD
Tamirim
Two issues: the IR sensor was not observed. And the insertion into the drive slots was very tedious. The drive did not want to go into the two holes in the case. I also replaced the Mac mini cooling fan whi . . .
Kullanıcı avatarı
Sorunum
Slow mechanical hard drive - upgrade to SSD.
Tamirim
Went smoothly.
Önerim
Could have used some closeups on the removal of the power plug clip - you just pull it out, but it wasn't clear if it was supposed to levered up or down. Also, could have used a closeup on pulling the power connector off the logic board; it d . . .
Kullanıcı avatarı
Sorunum
I was tired of long boot times and slow program launches on my late 2014 Mac Mini. Even with 16 GB of RAM, the thing was pokey.
Tamirim
The 2014 Mac Mini wasn't the most difficult Mac to work on that I've ever encountered, that honor goes to the pre-Unibody Macbook Pro. Ugh. Replacing the hard drive in the M . . .
Kullanıcı avatarı
Sorunum
I thought I could live with a slow spinning drive - I couldn't...
Tamirim
The replacement went without a hitch. I was dreading some kind of hiccup along the way, but the directions were so clear and detailed, I knew what to expect at each step. So in the end, I was able to successfully replacement my stock . . .
Daha fazla göster
