Magnetic Pickup Tool
  • Magnetic Pickup Tool
  • Magnetic Pickup Tool / Economy / Extending
  • Magnetic Pickup Tool / Pro / USA
The classic "antenna" style magnetic pickup tool. Includes cover that shields magnetic force from sides of magnetic tip, making it easier to feed through tight passages without sticking to other ferrous metals on the way down.
Removable pocket clip, rubberized black handle.
$4,99
$4,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
Magnets have a wide range of application—from keeping heavily-crayoned papers fastened to smooth-surfaced refrigerators, to finding out which of your friends ate your wrench set. Locate a magnetized tummy today with our Magnetic Pickup Tool.
Great for retrieving small screws from small spaces! Also can be held against side of screwdriver shaft to temporarily make it magnetized.
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
Internal 1Tb hard drive developed a SMART failure and would no longer boot.
Tamirim
After reading the guide several times, and making sure I had everything ready, I followed the instructions and successfully replaced with a 4 Tb drive.
Then reinstalled OS X.
Önerim
Remember, you can't read the guide too often!
Be ca . . .
Kullanıcı avatarı
Sorunum
Tamirim
Önerim
Be careful when removing the screen data cables.
Kullanıcı avatarı
Sorunum
Pretty much everything in the half-joking review sample text and then some, the things our clients do to machines never ceases to amaze me, from milk and coffee spills on Apple gear, to IBMs that have had something between display and keyboard in just the right spot to totally destroy the LCD and ke . . .
Kullanıcı avatarı
Sorunum
After about five years of heavy use on my Mid-2010 MacBook Pro, the battery had become disfigured, warping my trackpad along with it. Also, my computer was acting very sluggish.
Tamirim
After I received my iFixit delivery, I replaced my RAM and my battery using the 54 Bit Driver Kit and iFixit's easy guides. . . .
Kullanıcı avatarı
Sorunum
Needed to remove and destroy a hard drive for personal data protection prior to decommissioning and recycling an iMac.
Tamirim
Repair went fine. Recommended tools and online photo step by step guide was spot-on.
Önerim
Don't drop your tiny T6 tool on a hard surface. I did and it bent. I was able to make it servic . . .
Kullanıcı avatarı
Sorunum
I repair my own and friends' and clients' computers, I needed to stock up on tools and supplies.
Tamirim
To quote Al Green's song: 'How can you mend a broken heart?" These tools didn't do it...
Önerim
Yea. Don't ask a wiseacre like me for advice, I'll tell you to wear clean underwear in case you get in an accident . . .
Kullanıcı avatarı
Sorunum
I splashed the tiniest splash of hard cider from a bottle I almost knocked over but grabbed at the last moment. The laptop seemed fine... until about 12 hours later, when it ran out of battery. Dead, dead.
Tamirim
I got the clue it might be the MagSafe board from a few blog posts here and there, I took the w . . .
Kullanıcı avatarı
Sorunum
My iPhone 5 Battery had a mind of its own and drove me crazy with the sudden shut downs and incorrect energy readings. It was time to get rid of the dang thing.
Tamirim
Replacing the battery couldn't have been easier with the step-by-step guidelines. The guidelines did mention that it could be difficult to p . . .
Kullanıcı avatarı
Sorunum
The Apple iPhone and MacBook Pro both make it dificult for the user to replace the battery.
Tamirim
I started with the iPhone 5 battery replacement. The iFitIt instructions were very clear for the tasks. I used the iFitIt iPhone 5 battery kit with tools that worked fine. Do to my clumsiness I lost one o . . .
Kullanıcı avatarı
Sorunum
working for a elementary school with kids using laptops and headphones i always get broken connectors in the headphone jack.
I needed a way to remove the broken end of the headphone connector without taking the whole computer apart. I bought the tweezers set to accomplish this task and they fit nic . . .
Daha fazla göster
Bu ürünü satın alan müşteriler aynı zamanda aşağıdaki ürünleri de satın aldı
