Magnetizer/Demagnetizer
  • Magnetizer/Demagnetizer
  • 360°
360
$4,99
$4,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
Never lose a screw again.
  • Magnetize your screwdrivers to allow them to grab small screws.
  • Demagnetize your screwdrivers to safely work on sensitive electronics.
  • Alternate magnetizations as many times as your heart desires!
To magnetize your screwdriver, insert the end of it into the "Magnetize" hole. To demagnetize your screwdriver, repeatedly pull the entire length of the screwdriver through the "Demagnetize" hole.
Note: color may vary.
Ürün Videosu
Onarım hikayeleri
richschmelter's Story Photo #460818
richschmelter's Story Photo #460800
Sorunum
After many years of use, the dock connector on my iPhone 4s had become corroded and was causing problems with the phone such as poor charging and not being able to shut the phone down (it would just restart itself when you tried to power it off).
Tamirim
The repair went incredibly well. I've built and repair . . .
Sorunum
The phone had water damage
Tamirim
It went fine, the last step with the little tiny hex nut was annoying but I just used needlenose plyers to take it out, and then put the display bracket screw into it and used a screwdriver to tighten it back in, and then held it with plyers again and just screwed the top d . . .
Sorunum
Internal 1Tb hard drive developed a SMART failure and would no longer boot.
Tamirim
After reading the guide several times, and making sure I had everything ready, I followed the instructions and successfully replaced with a 4 Tb drive.
Then reinstalled OS X.
Önerim
Remember, you can't read the guide too often!
Be ca . . .
Sorunum
Tamirim
Önerim
Be careful when removing the screen data cables.
Sorunum
need toolkit like repair business toolkit
Tamirim
my video card not working give me black screen I open the card and clean it inside at arctic silver and put the card in the oven and put thermal paste I test the video card not working :) and I am very very happy with this toolkit Thank you ifixit :)
Önerim
if you ne . . .
Sorunum
Las computadoras de disco mecánico ya tardaban mucho en encender y a cada rato salía la pelota playera dando vueltas, signo de que el sistema está pensando o atorado.
Tamirim
La reparación fue sencillísima, las cosas que compré en iFixit me llegaron rapidísimo! Y las guías me sirvieron perfectamente. . . .
Sorunum
The yellow light of death on the ps3 wouldnt let me use my sp3
Tamirim
Easy as cake, and MJ's instructions where exelent! ... nto to mention how easy she is on the eyes.
Önerim
Makesure you use the right driver for the screw, it was easy to strip the bolt holding the HDD casing, but it all went without a hitch after . . .
Sorunum
Pretty much everything in the half-joking review sample text and then some, the things our clients do to machines never ceases to amaze me, from milk and coffee spills on Apple gear, to IBMs that have had something between display and keyboard in just the right spot to totally destroy the LCD and ke . . .
Sorunum
My new $420 refurbished 2015 Mac Mini has security torx, so i couldn't replace the lazy HDD by an Intel 520 SSD... until i fixit !!
What is strange is that my friend Mac Mini, exactly the same, has no security torx but standard
Tamirim
not so difficult, i think less time than 2012 mac mini.
Önerim
Very easy to upgra . . .
Sorunum
The Macbook Pro was working really slow. My first thought was a failing harddrive, so i took it out, at did a test, no error. Then i thought it might be that ribbon cable. Since i live far away, i wanted to order from ifkxit because of my previous success with them. It took only 6 days to receive th . . .
Daha fazla göster
