Mahi Driver Kit - 48 Bit Driver Kit
  • Mahi Driver Kit - 48 Bit Driver Kit
$29,99
$29,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Ürün Detayı
Açıklama
Açıklama
The Mahi Driver Kit includes iFixit’s 1/4" aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top—plus 48 driver bits.
Spanners, Squares, and Splines—oh my! In addition to standard Phillips and Flathead, this bit kit includes all the 1/4" form factor bits you’ll need to handle the toughest and torque-iest fasteners in any home or shop project.
All our next-gen bit kits have been re-engineered for maximum utility. The bit kit lid is held in place with magnets to increase product lifespan (no more broken hinges or clasps) and also mounts to the back of the bit kit case to keep it out of the way while you do your work. Or, if you need help keeping your screws and parts organized, use the lid’s integrated sorting tray.
Kit İçeriği
Kit İçeriği
  • Easy-to-Open Magnetized Case
  • Lid with Built-in Sorting Tray
  • 1/4" Aluminum Bit Driver
  • 1/4" Screwdriver Bits
    • Phillips - 0, 1, 2, 3
    • Flathead - 4, 6, 8 mm
    • Hex Security - 4, 5, 6, 7, 8 mm
    • Hex Security SAE - 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
    • Pozidriv - PZ1, PZ2, PZ3
    • Spanner - 4, 6, 8, 10, 12
    • Square - 2, 3
    • Spline - M5, M6, M8
    • Torx Security - TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
    • Tri-wing 1, 2, 3, 4
    • Clutch 1, 2, 3
    • Schrader Valve
    • 1/4" Driver to 1/4" Socket
