Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Moray Driver Kit
  • Moray Driver Kit
  • Moray Driver Kit
  • Moray Driver Kit
  • Moray Driver Kit
Moray Driver Kit
$19,99
$19,99
Ürün Detayı
Açıklama
Açıklama
Meet the Moray, Minnow’s slightly bigger brother. Measuring a portable .9" x 3.1" x 4.9", the Moray is the perfect every-day-carry toolkit or junk drawer standby to prevent your stuff from becoming junk.
We built the Moray using data from thousands of repair manuals and teardowns, ensuring you have a compact assortment of bits for electronics and home repair. Our 4 mm precision bit driver handle has an integrated SIM Eject pin, magnetic bit socket, knurled grip, and swivel top—and the 32 precision driver bits have a 4 mm hex shank and extended-reach long necks.
Standard and security bits like Phillips and Pentalobes will get you into most electronic devices and small household appliances, and an assortment of Hex and specialty bits come in handy for furniture and older devices. Whether you're a professional fixer or a weekend warrior, the Moray has what you need to disassemble and repair smartphones, laptops, new and vintage game consoles, kitchen appliances, and more.
Kit İçeriği
Kit İçeriği
  • Easy-to-Open Magnetized Case
  • Lid with Built-in Sorting Tray
  • 4 mm Precision Bit Driver with Integrated SIM Eject Tool
  • 32 Screwdriver Bits
    • Phillips - 000, 0, 1, 2
    • Flathead - 1, 2.5, 4 mm
    • Torx - T3, T4, T5
    • Torx Security - TR6, TR8, TR10, TR15
    • Pentalobe - P2, P5
    • Hex - 1.5, 2.5, 3, 4 mm
    • Tri-point - Y000, Y00, Y0, Y1
    • Nut Driver - 2.5, 5 mm
    • Gamebit - 3.8, 4.5 mm
    • Triangle - 2, 3 mm
    • iPhone Standoff Bit
    • Oval Drive
Teknik Özellikler
Teknik Özellikler
Driver Material:
Polymer
Foam:
EVA
Bit Metal:
S2 Steel
Case Material:
ABS
Dimensions:
.9" x 3.1" x 4.9" / 2.2 x 7.8 x 12.4cm
Müşteri Yorumları
