Phillips #2 Screwdriver
  • Phillips #2 Screwdriver
$2,99
$2,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ürün Detayı
Açıklama
Açıklama
Unless you require a #2 Phillips driver for a deeply recessed screw, we recommend purchasing our 6-in-1-Screwdriver, which includes a Phillips #2 driver.
Onarım hikayeleri
Kullanıcı avatarı
Sorunum
Computer was constantly running fans with little to no actual load. Upon closer investigation the computer was getting as high as 90 degrees Celsius when doing moderately demanding tasks.
Tamirim
Opened the case and saw a bunch of dust everywhere. After the dust was removed the real problem revealed itself. . . .
Kullanıcı avatarı
Sorunum
Replaced built in optical drive with 250GB SSD drive. System was running really slow.
Tamirim
It went well. Followed instructions and was pretty straight forward. Ran into a few hurdles....The screws can easily fall down into the case, which was very annoying. There is also a cable that has a very sensitive . . .
Kullanıcı avatarı
Sorunum
No facilities available in Australia, apparently.
Tamirim
Quite ok. Thanx for online instructions.
Önerim
Spludger
invaluable.l
Kullanıcı avatarı
Sorunum
My iMac 27 Inch i5 always frozen...
Tamirim
Very well, I managed to happily. It 'just install "Fan control" fan set at maximum speed and the problem is solved!. For an excess of zeal, oh then apart my iMac 27 to carry out additional cleaning.
Önerim
No, nothing special
Kullanıcı avatarı
Sorunum
The power supply of my Imac was broken
Tamirim
My iMac is a 24" aluminum one, unfortunately there was no official guide on the website. However, there was a guide for changing the power supply in a 20" iMac, so I used that. There was also a video of the friendly lady, who made the repair look very easy. I al . . .
Daha fazla göster
Bu ürünü satın alan müşteriler aynı zamanda aşağıdaki ürünleri de satın aldı
