Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Pokit Multimeter and Oscilloscope
  • Pokit Multimeter and Oscilloscope
$88,99
$88,99
Ürün Detayı
Açıklama
Açıklama
Pokit measures, displays and logs a wide range of parameters including voltage, current, resistance and temperature. It also provides a continuity and diode checker. Pokit is ideal for low voltage electronics, automotive applications, home automation, etc.
Turn your smartphone into a multimeter, oscilloscope, and data logger. The Pokit meter connects wirelessly to your smartphone and app. Simply touch to change modes and settings, and pinch and drag to pan and zoom waveforms.
Included in the box:
  • Pokit Meter with Convenient Retractable Leads
  • Installed Battery and Fuse
  • Spare Fuse
  • Wire Grip Clips
  • Carry Pouch (color may vary)
Specifications:
  • DC Voltage Measurement: 10mV to 60V DC ± 1%
  • AC Voltage Measurement: 10mV to 42V RMS ± 1%
  • AC/DC Current Measurement: 1mA to 2A ± 1%
  • Resistance Measurement: 1 to 1M Ohm ± 5%
  • Ambient Temperature Measurement: 0 to 60° C ±1°C / 32 to 140° F ±2°F
  • Continuity: < 30 ohms
  • Diode Check: < 1.5V
  • Sampling: 14-bit, 1M samples/s
  • Acquisition Window: 10ms to 10s
  • Logging Rate: 1s to 1 day
  • Logging Duration: 1 year (at 6 hours / sample)
  • Bluetooth Range: 10mts / 30ft
  • Operating Temperature: 0 to 60° C / 32 to 140° F
  • Average Battery Life: 6 months
  • Compliance: RMC, FCC, CE
  • Lead Span: 400mm / 16 inches
Teknik Özellikler
Teknik Özellikler
Model #:
POK-WHT
