Precision Screw Extractor Set
  • Precision Screw Extractor Set
$19,99
$19,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
Extract tough stripped screws without damaging the device.
  • Safely remove stripped screws and replace the age-old practice of coating the screw-riddled device with wax and feathers and hurling it into the sun.
  • We know how annoying stripped screws can be. Before you resort to the rotary tool or super glue, give these little guys a try.
  • Hardened bits with 4 sharp points for gripping what's left of the screwhead safely.
  • Extractor tips are double-sided and reversible:
    • 3 drivers have the same size bits on each end, and 1 driver has different sizes on each end—a total of 5 different bits.
  • Anodized machined aluminum handles with swivel tops and pocket clips.
  • Made in USA.
Not
This tool requires some mechanical aptitude and careful feel. If you stripped a screw while carefully using the correct type of driver the first time, it is possible you will not be successful with this tool. Screws that are cross-threaded, jammed, or glued in place will be very difficult to remove with any tool. Our Screw Extracting Pliers are easier to use, but will not grip recessed screws.
Onarım hikayeleri
sjking's Story Photo #1155636
sjking's Story Photo #1155638
Sorunum
I wanted to add a second primary SSD to my MacBook Pro.
Tamirim
The first time around it went terribly. I bought a multi driver set to remove the screws. When I got to the Airport/Bluetooth housing, I stripped the screw. I ended up ordering the precision screw extractor set to try and remove the stripped scr . . .
Thomas Kremser's Story Photo #1049162
Sorunum
A 1940's Buescher 400 cornet had a broken screw on the water key, that was rusted-fast.
Tamirim
The repair went great. I used the Precision Screw Extractor set.
Önerim
The Precision Screw Extractor worked perfectly. I needed to back out the screw without ruining the threads or marring the surface or denting any of . . .
Sorunum
I stripped one of the tiny screws inside the DVD bay of an HP Envy laptop while trying to remove the bottom cover and it's 13 billion screws. Ultimately I was just trying to get in to unplug the speakers from the motherboard as they were generating a crazy hiss and static every time a sound was play . . .
Sorunum
The pentalobe screws refused to come out
Tamirim
I had read somewhere that Apple may use Loctite to insert the screws. I researched on the Internet how to loosen up Loctite. The answer was to use HEAT. I heated up the screws, using my glue gun nozzle (without the glue, of course) and when the screw was hot, . . .
Sorunum
I decided my new Macbook Pro needed a new Solid State Drive. Since I was going to be inside the case anyway I decided to put in a Data Doubler from OWC. A Data Doubler basically is used to replace your optical drive with a hard drive or SSD. The SSD upgrade went off without a hitch. The Data Double . . .
Sorunum
Cracked Screen
Tamirim
Isckack didnt stick because of a Tag that was already on the Iphone
Önerim
Buy the Nat
Sorunum
need to take apart a nintendo Wii
Tamirim
Havent started it yet, but satisfied with my purchases
Önerim
read the bible =)
Daha fazla göster
Bu ürünü satın alan müşteriler aynı zamanda aşağıdaki ürünleri satın aldı
