Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Smoke Absorber Hakko FA-400
  • Smoke Absorber Hakko FA-400
$69,99
$69,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Nintendo Switch Setleri
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
Ürün Detayı
Açıklama
Açıklama
Breathe easy with the Hakko FA-400 bench top smoke absorber. The FA-400 removes soldering smoke and fumes quickly, safely and efficiently. The unit can be used in a vertical (standing up) position or low-profile position (laying down.) When used in the low-profile (laying down) position, efficiency and air flow is increased by approximately 2.6 times.
• Unit is made of non-sloughing static dissipative conductive material and operates quietly
• Standard activated carbon filter (PN: A1001) absorbs up to 80 percent of the odors from the air and is easy to replace
• Can be used vertically (upright) or horizontally/low profile (laying down)
• Uses existing 493 filters and accessories
• ESD-safe by design
Made in Japan
Available for shipment only to the USA due to voltage requirements.
