Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Spudger Retail 3 Pack
  • Spudger Retail 3 Pack
$8,99
$8,99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
Tough antistatic tool used for working on electronic devices and doing DIY electronic repair. It's an essential tool for everything from repairing a broken smartphone or tablet screen to replacing an old battery or hard drive. Tough (and heat resistant) enough for using as a soldering aid.
Onarım hikayeleri
Kullanıcı avatarı
Jill Benrey's Story Photo #1319762
Jill Benrey's Story Photo #1319764
Jill Benrey's Story Photo #1319761
Sorunum
Fan was overheating xbox. Son couldn't play his games with out his xbox shutting off.
Tamirim
Fan replacement went pretty well. I did watch a couple youtube videos which helped me not disconnect some things that can be fussy and break.
Önerim
Fun to show your kids you had a life before being a mom and you actually k . . .
Kullanıcı avatarı
Audrey Sampson's Story Photo #1336642
Sorunum
As you can see, the battery in my MacBook was swelling and had pushed the trackpad out of the case. Apple support said that my device was too old to service in store, so I should find an authorized repair shop. But I live 2-3 hours from the nearest options, so I asked my office IT guru if he knew of . . .
Kullanıcı avatarı
Sorunum
Computer wasn't cooling, fans made clicking noise.
Tamirim
Flawlessly. The repair guide is very well laid out. Follow the steps, be patient, and the process will work.
Önerim
1.) If you're going to the trouble of replacing fan(s), check out the battery while you're at it. Replacing that as well isn't that much more . . .
Kullanıcı avatarı
Sorunum
The Xbox kept losing wifi connection sporadically. At boot up. So I kept rebooting it until it connected. Very random. When the wifi was down, it wouldn't even see my neighbor's wifi. So I suspected the wifi card was bad. Sometimes it worked, sometimes it didn't.
Tamirim
The repair was easy using the guide. . . .
Kullanıcı avatarı
Sorunum
I had a Late 2008 MacBook 13" (5,1) laptop and was saddened to realize that part of the keyboard was not working anymore. I wanted to get the laptop working again so I could give it to my son to use as his first computer.
I found this "Guide in Progress," "Upgrading your 2.0Ghz 13" Aluminum Unibod . . .
Kullanıcı avatarı
Sorunum
Old battery would need charging every day. I read a lot
Tamirim
Concise and clear.
Önerim
Don't be afraid to try. I hope to get 5 more years out of my Kindle 2
Kullanıcı avatarı
Sorunum
Hard drive had failed OOW
Tamirim
Repair went well.
BTW, I did not do the dual drive install, just replaced the original.
Only issue was The pointing devices acted weird and bluetooth was not behaving as expected. I posted the problem asking for solutions and someone explained that it sounded like there w . . .
Kullanıcı avatarı
Sorunum
Controllers nor wifi would connect to the Xbox
Tamirim
It went fantastic
Önerim
Be careful if you have a broken thumb
Daha fazla göster
