Universal Bit Kit
  • Universal Bit Kit / New
  • 360°
360
Universal Bit Kit
The complete bit set for any repair enthusiast.
$99.99
$99.99
Ürün tekrar stoklarımızda mevcut olduğunda size bir mesaj göndereceğiz.
Ürün Detayı
Açıklama
Açıklama
  • 128 steel bits in both 4 mm and 1/4" sizes for precision work and large torque application.
  • CNC machined aluminum driver handles for both 4 mm and 1/4" bits provide plenty of grip while driving screws.
  • Elegant oak case keeps all components secure and conveniently displayed.
Bit List
  • Phillips 000, 00, 0, 1, 2, 3
  • Flathead 1, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 5, 6, 7, 8 mm
  • Torx T2, T3, T4, T5
  • Torx Security TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
  • Hex 0.7, 0.9, 1.3, 1.5 mm
  • Hex Security 2, 2.5. 3, 3.5, 4, 5, 6, 7, 8 mm
  • Hex SAE 1/16
  • Hex Security SAE 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
  • Nut Driver 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12 mm
  • Nut Driver SAE 1/4, 3/8
  • Square 0, 1, 2, 3
  • Pozidriv Pz0, Pz1, Pz2, Pz3
  • JIS J000, J00, J0, J1
  • Torq-set 6, 8, 10
  • Tri-wing 0, 1, 2, 3, 4
  • Tri-point Y000, Y00, Y0, Y1
  • Pentalobe P2, P5, P6
  • Clutch 1, 2, 3
  • Gamebit 3.8, 4.5 mm
  • Spanner 4, 6, 8, 10, 12
  • Triangle 2, 3 mm
  • Spline M5, M6, M8
  • Oval Bit
  • SIM Eject Tool
  • Magnetic Pickup Tool
  • Schrader Valve
  • Hook and Loop Fastener
  • 1/4" to 4 mm drive adapter
  • 1/4" driver to 1/4" socket adapter
  • 1/4" driver to 3/8" socket adapter
  • 1/4" socket to 1/4" driver
Ürün Videosu
Onarım hikayeleri
Kullanıcı avatarı
Benjamin Rodriguez's Story Photo #1013595
Sorunum
Battery is damaged
Tamirim
Quite easy
Önerim
If you put more guides that are good to learn
Kullanıcı avatarı
Sorunum
User spilled coffee onto their keyboard, computer shut off.
Tamirim
Better than anticipated. First in-house repair of a logic board.
Önerim
Magnetic board to organize screws and the 128-bit kit to have everything.
Kullanıcı avatarı
Sorunum
My Apple watch screen suddenly came off of the frame as the adhesive material must have some how been damaged. So the screen was hanging from the frame by a few tiny connections!!!!
Tamirim
I took it to Apple to get it fixed and they quoted me 3 weeks time plus 275$+13% tax to fix it as I was out of warranty . . .
Kullanıcı avatarı
Sorunum
The Problem started when my dog knock over water on my wife mac.
Tamirim
The repair went well, though i should of bought the ifix it business tool kit because some of those cable are really small.
Önerim
I never done a repair that did not had any remaining screws. Just follow the step that Ifix it provides and you w . . .
Kullanıcı avatarı
Sorunum
It had been dropped
Tamirim
My blind grandmother could have fixed it....
Önerim
If you need help go to ifixit
Kullanıcı avatarı
Sorunum
The battery of my Macbook Pro 15 - 2011 died on me.
Tamirim
It took about 7 min and was great.
Önerim
Just read the instruction before you order.
Kullanıcı avatarı
Sorunum
The current 500GB drive had run out of space, so we upgraded to 4T.
Tamirim
Everything went well, however a word of caution. The video cable mount is very tiny and you need small hands to reseat it.
Önerim
You don't need to remove the LCD screen, you can reach the screws that hold the drive in place by simply liftin . . .
Kullanıcı avatarı
Sorunum
Problem - Daughter's Boyfriend Electrical Engineer - Idea for gift!
Tamirim
He loved it! Several times while he was at our house, I found him simple pulling out each bit and playing with the two drivers. My daughter said he had to hide them from his Dad. Maybe Dad will get a set of his own.
Önerim
Oh yes, advice... . . .
Daha fazla göster
