Sorunum
My iPhone 4s was in a bag along with a water bottle that leaked. The phone was soaked and after drying, the camera flash would not turn off and the vibrate switch would no longer function.
Tamirim
The camera was a breeze. The vibrate switch a little more challenging: you have to take most of the phone apart to get to it. But the guides were great, and while at first I thought the magnetic project mat a little overkill, it's really quite handy.
The phone started right up when I reassembled it. The camera worked and the flash no longer stayed on. The vibrate switch still didn't work, however. I saw a lot of water damage / corrosion on the motherboard right around where the vibrate / volume cable plugs in, so the problem is likely on the motherboard.
Önerim
Pay close attention to the part about prying the microphone away from the case. I had the directions printed so I didn't see the close-up image and ended up forgetting about it and tearing the cable. Luckily the whole point was to replace the cable so it didn't matter.
0 Yorum
