Sorunum
Wanted to add an SSD as my boot drive and keep the stock 500GB drive in as a data drive.
Tamirim
Smoothly. Took approximately 1.5 hrs to complete. The toolkit was a perfect match for this project. The screwdriver set was overkill, but every other piece of the kit was used and made it as simple as following the instructions.
Önerim
The only piece of advice is that it doesn't matter which drive is plugged into which sata port on the logic board, as you set which drive is the boot drive in the OS. In my case I cloned the existing drive onto an SSD AND I swapped the sata cables and therefore the logic board sata plugs. It still booted to the original stock drive, so I switched it in the system settings and now it boots from the SSD.
0 Yorum
