Ana içeriğe geç
Bu söküm üzerinde çalışılıyor – Son değişiklikleri görmek için düzenli olarak yenile!
Neye ihtiyacın var
  1. (TC) PlayStation Teardown, (TC) PlayStation Teardown: adım 1, 1 resimden 1.
    • Flip the unit upside down to access the six screws on the bottom.
    • Remove the six screws indicated with a Phillips-head screwdriver. All the screws are of the same length.
  2. (TC) PlayStation Teardown: adım 2, 1 resimden 1.
    • Turn the unit back over, and pull the top half up and away from the device.
  3. (TC) PlayStation Teardown: adım 3, 1 resimden 1.
    • Unplug the laser assembly's power cable and ribbon cable from the main board.
    • Remove the two screws on the memory card/controller port, disconnect the ribbon cable, and lift it out of the case.
  4. (TC) PlayStation Teardown: adım 4, 2 resimden 1. (TC) PlayStation Teardown: adım 4, 2 resimden 2.
    • To remove the power supply, disconnect the cable and remove the two screws, then lift it out of the case.
  5. (TC) PlayStation Teardown: adım 5, 2 resimden 1. (TC) PlayStation Teardown: adım 5, 2 resimden 2.
    • Remove the 3 screws from the shield.
  6. (TC) PlayStation Teardown: adım 6, 2 resimden 1. (TC) PlayStation Teardown: adım 6, 2 resimden 2.
    • Remove the 5 Phillips screws.
    • You can now lift the main board out of the case.
  7. (TC) PlayStation Teardown: adım 7, 2 resimden 1. (TC) PlayStation Teardown: adım 7, 2 resimden 2.
    • Lift the RF shield out of the case.
  8. (TC) PlayStation Teardown: adım 8, 2 resimden 1. (TC) PlayStation Teardown: adım 8, 2 resimden 2.
    • Reinstall the RF shield by dropping it in and lining up the slots and tabs.
  9. (TC) PlayStation Teardown: adım 9, 2 resimden 1. (TC) PlayStation Teardown: adım 9, 2 resimden 2.
    • Replace the main board. Only install the screws indicated in red.
  10. (TC) PlayStation Teardown: adım 10, 1 resimden 1.
    • Replace the top shield, and secure with the 3 screws indicated.
    • Reinstall the memory card / controller module. Connect the ribbon cable and replace the 2 screws.
  11. (TC) PlayStation Teardown: adım 11, 1 resimden 1.
    • Align the optical drive assembly with the three pegs.
    • Reconnect the power and data cables for the optical drive.
  12. (TC) PlayStation Teardown: adım 12, 1 resimden 1.
    • Slide the cover on the system in the same way you took it off and replace the black screws indicated.
  13. (TC) PlayStation Teardown: adım 13, 1 resimden 1.
    • Plug in the console and turn it on.
    • Thanks for looking at my teardown!
Nick
88.851 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.535 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 43,032
